- 30 Jun 2006
- Cardiff
@Absolutely Clueless So you are youngish so you are a wannabe grumpy old man? interesting. I will have to veto it with 'the others'.
Yeah, that's been pretty readily available which is good to see. £700 over MSRP for that seems a bit madness to me. The other day the Suprim was available for the same price.The Vanguard has been up for for 2600. I was almost tempted. But I already had 4 MSI 5 series and I fancy a change.
All I know about the vanguard it has 1 or 2 less heatpipes and has a my little pony figurine with it. I can't see it being that much diff. And if you a longterm suprim user then you would probably know that suprim bios is pretty much closed off power limit wise. A paltry 104%.Yeah, that's been pretty readily available which is good to see. £700 over MSRP for that seems a bit madness to me. The other day the Suprim was available for the same price.
The Aorus Master was available for £2480 (very briefly), which would weigh on my mind if i paid £2,600 for a Vanguard or Suprim. Anyway, I don't want to pay that much for a 5090 so it's all a bit mootAll I know about the vanguard it has 1 or 2 less heatpipes and has a my little pony figurine with it. I can't see it being that much diff.
Let's get the Zotac solid. We can be twinsies.....The Aorus Master was available for £2480 (very briefly), which would weigh on my mind if i paid £2,600 for a Vanguard or Suprim. Anyway, I don't want to pay that much for a 5090 so it's all a bit moot![]()
...get a room...Let's get the Zotac solid. We can be twinsies.....
Shut up you tart, you're my Astral LC twinsy anyways.........get a room...![]()
Is Gibbo personally delivering 5090s now? Blimey.@Gibbo thank you for delivering the MSI 5090 quickly![]()
It is tempting... Gibbo said OCUK are hoping to get a c.1,000 batch of 5090s in mid-May, targeting £2 - 2.1k. I assume it will be a Palit or Zotac card, but i'm just guessing. Maybe that will swing me. Then I will need to rush and buy an Antec Flux Pro case and C1500 PSU!Let's get the Zotac solid. We can be twinsies.....
You can pay an extra £500 and he will get it to your door within 4 hours in his McLaren.Is Gibbo personally delivering 5090s now? Blimey.
...not for longShut up you tart, you're my Astral LC twinsy anyways......
. Just about to fire up my D5 pump to see if I'm imagine the noise difference...That reminds me I need a new case for another build. That's a nice looking case. It has been donkey years since I had an Antec case.It is tempting... Gibbo said OCUK are hoping to get a c.1,000 batch of 5090s in mid-May, targeting £2 - 2.1k. I assume it will be a Palit or Zotac card, but i'm just guessing. Maybe that will swing me. Then I will need to rush and buy an Antec Flux Pro case and C1500 PSU!
Ahh right so you do full watercooling setups? Never got into that. Came close a few times but never went all in so to speak. Although I would be tempted to do a Mora watercooling setup connected to one of those dinky SFF mitx cases for lulz...not for long. Just about to fire up my D5 pump to see if I'm imagine the noise difference...
I always just pick the best airflow case. The Lian Li Lancool II mesh got great reviews in 2020 when I built my first gaming PC, however, it is rather too small for a 5090. Plus, I can upgrade to the big boi Artic LF III 420m AIO if I get the Flux Pro (because the 9800X3D needs even more cooling... said no one ever)That reminds me I need a new case for another build. That's a nice looking case. It has been donkey years since I had an Antec case.
Oh dear! I know you waited ages for that Suprim 5090. What did you send it in for and how did it go?It not as bad as you think. I have done this. I went through OCUK. They ship it off to Poland. They 30 days to repair it or you get your money back if it was bought within a month . Mine arrived back on the 29th day. MSI Poland jsut gave me a brand new card as when it came back to me it was a brand new sealed unit. Still had coil whine though, lulz.
Funnily enough I had to Rma a suprim 5090 although a totally different issue to my suprim 4090 and within in the first few weeks...I am sure it a sign but I will be damned if I know what.
I don't find high end top tier cards any more reliable than budget range cards. I have had to RMA a Suprim top end card each generation and had to RMA Astal LC due to intermittent fan connector. I could have done it myself but it was under warranty anyways. I also had to RMA an Asus 3090 TI LC. Maybe I should just stick to air cooled cards.
If you are older you can join the grumpy old barstewards crew like me and others who hide behind a strict veil of anonymity. GERROF MAH BLOODY LAWN!!!!!
Errrrrr....errrrr. I have the 9800x3d setup and a LF3 420mm, You could cool that cpu with handheld fans...I always just pick the best airflow case. The Lian Li Lancool II mesh got great reviews in 2020 when I built my first gaming PC, however, it is rather too small for a 5090. Plus, I can upgrade to the big boi Artic LF III 420m AIO if I get the Flux Pro (because the 9800X3D needs even more cooling... said no one ever)![]()
I have. They decided to get a CPU AIO for the new AM5 series build in November, then Air 5090, was too used to low fans I think, the tried 2 Astral AIOs but pump noise...so, probably make the effort and go back to full set up...Ahh right so you do full watercooling setups? Never got into that. Came close a few times but never went all in so to speak. Although I would be tempted to do a Mora watercooling setup connected to one of those dinky SFF mitx cases for lulz
Haha, what's your 50 series count at this point? LolThe Vanguard has been up for for 2600. I was almost tempted. But I already had 4 MSI 5 series and I fancy a change.
Higher than his body count I suspect. Moving on....Haha, what's your 50 series count at this point? Lol
