My Sapphire Radeon RX 7900 XT Pulse I purchased from ocuk has a hidden manufacturing defect. At low temperatures it fails to fully load the VBIOS. This completely prevents Linux from starting from cold boot. Windows can boot, but it won't load the GPU driver. Rebooting a couple times resolves the problem, because the card heats up in the process. This defect was hidden, because I purchased it in the summer, and it only presents itself below 22 C room temperature. It took me a long time to troubleshoot this. I wasn't sure if it's a driver issue, or some other components in my only PC.
Once I started to suspect that this is a GPU error, I sent it back to ocuk for RMA. This was on 7th February.
On 27th February, ocuk replied that they tested the GPU by Rebooting several times and running a stress test, and there's no fault found. They returned the card.
In my machine it was still not working properly, so I thought it must be something else wrong. I sold the 7900 XT on ebay and started planning a new build. A couple days later, the ebay buyer wrote to me that they experienced the same issue with this GPU. I apologized, payed for the return and refunded them.
I sent back the GPU to ocuk the second time on 10th April, including an even more detailed description on how to replicate the issue, and what not to do while testing.
On 23rd April I received this from ocuk:
'We have managed to confirm the fault with the card this time around. As we no longer have any new stock of the GPU, we will be replacing this with a B-grade version linked below.
www.overclockers.co.uk
Please ignore any warranty information for this as the warranty should go from the original product.''
4 days ago I received the replacement card. It has terrible coil whine. I can hear it from the other room. I recorded it with my phone, but the recording isn't perfect, in reality it's even louder, it gives me a headache.
This is where the story gets really infuriating. I refused to accept this GPU as a replacement and asked them to either provide a faultless replacement or a refund. This was their response:
'While coil whine can be annoying to some users, it is generally not considered a fault by manufacturers because it does not affect the functionality of the graphics card or other components. In other words, the graphics card will still perform as intended even if it has coil whine.
Due to this we are unable to get this back for a refund unless there is a fault with the item.'
I asked them to escalate this issue.
Today I asked for an update. This was the response:
'As the item was accepted as a replacement before it was shipped to you, unless there is a hardware fault with the product which affects the performance of the item we are no longer able to accept this back as a refund.
If you are unhappy about this outcome, then you can submit a complaint web ticket via the link below so the issues can be escalated to a manager for you.'
followed by a link to raise another ticket.
I have never explicitly accepted the replacement.
What are my options here? I don't like it that I have to ask the public, but I believe people should now that these things can happen at ocuk.
Sapphire Radeon RX 7900 XT Pulse 20GB GDDR6 PCI-Express Graphics Card
Order B Grade Sapphire Radeon RX 7900 XT Pulse 20GB GDDR6 PCI-Express Graphics Card now online and benefit from fast delivery.
