Have you forced it to 120hz in the display options instead of leaving it in the default setting?Have a Xiaomi 15u (got it at Uk launch) - camera is generally superb (so much flexibility) but have noticed it tends to mess skin tones up on outdoor portrait shots - my OP13 does better in this type of shot. I'm sure after a few updates (when Xiaomi actually get them out) will improce the camera further. Bigger problem for me is just that in day to day use, the OP13 is much, much nicer/smoother to use - its' a far nice daily device (with considerably better battery life than the Xiaomi also).
Thanks - forcing 120hz is also fine but still some moments of micro stutter/hiccups - usually when returning to the home screen from the Google feed. It's not a massive issue, just that the device just doesn't feel as fluid as my OP13. Scrolling etc and app opening is still very good though.Have you forced it to 120hz in the display options instead of leaving it in the default setting?
Also some apps need to be manually toggled on for 120hz.
My 15 ultra is as smooth as butter.
This week's update has seemed to improves the stutter now in the launcherHave you forced it to 120hz in the display options instead of leaving it in the default setting?
I'm currently on 2.0.103.0Which HyperOS version are you on mate, I don't see any updates.
Thanks.I'm currently on 2.0.103.0
Case looks good!
Mine was purchased direct from Xiaomi UK. Update came a few days ago with March security update.Thanks.
I'm on 2.0.90.0. Nothing more available.
Do you have the global model?
Good to know. I'll give it a few days cheers.Mine was purchased direct from Xiaomi UK. Update came a few days ago with March security update.
What do we think of the Huwaei Pura ?
Finally here yayThis week's update has seemed to improves the stutter now in the launcher
Had a quick look. I don't see anything special about it. I'd rather save a few quid and just get the pro.What's people's thoughts on the Poco F7 ultra?
Some people are praising it quite a bit but others seem to think it's overpriced?
How are people getting on with the one plus 13? Seems it can be got for about £500~. Is the camera any good? Gets mixed reviews.
It's an absolutely fantastic phone. Camera is very good. Although I don't tale that many photos.
Thanks, it seems it may not be a global rom at that price. (Deal Monday) And I'm not sure I can be bothered with the hassle of the potential of things not working....
