- 28 Mar 2025
- UK
Good going lad!
Easy install for the alphacool?
it is fairly simple. Obviously hands are shaking as you dismantle 2k card
Ventus cooler is very easy to take off. It's using putty, not the pads, so it was a bit tricky you just apply pulling pressure and wait, the putty will let it go.
That o11 evo rgb. Its roomy enough for 3x360 rads (bottom one is tx360 crossflow?What case are you using? I'm tempted to consider watercooling a 5090 as a pet project, as I've never done it before.
Especially if I got my hands on a Ventus/Palit
Could you give an idea of the total costs?
My basket at OcUK:
- 1 x Barrow Dabel-28b 360mm Triple Fan Radiator with 28mm Depth - Black (SKU: WC-005-BA) = £44.99
- 1 x Barrow Dabel-20b 360mm Triple Fan Radiator with 20mm Depth - Black (SKU: WC-00K-BA) = £64.99
- 1 x Alphacool NexXxoS XT45 Full Copper Radiator - 360mm (SKU: COO-ACL-04420) = £79.99
- 1 x Corsair Hydro X Series XD5 RGB Black Reservoir / Pump Combo - 330ml (CX-9040006-WW) (SKU: WC-02S-CS) = £149.99
- 1 x Alphacool Core 1 CPU Water Block - Black (SKU: WC-0DE-AC) = £99.95
- 1 x Alphacool Core GeForce RTX 5090 Reference ARGB Graphics Card Water Block (SKU: COO-ACL-04399) = £199.99
- 3 x EK Water Blocks EK-Tube ZMT Matte Black 16/10 mm - 1m (SKU: WC-535-EK) = £5.99
- 2 x Alphacool Eiszapfen 16/10mm Deep Black Compression Fitting - Six Pack (SKU: WC-08X-AC) = £35.99
- 2 x Mayhems - PC Coolant - X1 Premix - Eco Friendly Series, 1 Litre, Clear (SKU: WC-035-MH) = £14.98
- 10 x Barrow 90 Degree Rotary Fitting - Black (SKU: WC-07Q-BA) = £3.95
- 4 x Barrow 45 Degree Rotary Fitting - Black (SKU: WC-07D-BA) = £3.95
- 1 x Barrow 30mm Male to Female Extension Adapter - Black (SKU: WC-05X-BA) = £3.95
Total: £819.04 (includes delivery: £0.00)
So that's what you probably looking for
Rich (BB code):My basket at OcUK:
What riser cable youre using? My linkup only works as 8x gen4 with 5090. But with 3080 full 16x gen4Installed mine last week, nothing special about installation, I only used Aurora blocks from Alphacool before, but this Core block is noticeably better quality. I works pretty well too, both GPU and VRAM temp went down by ~20C.
Yes it does, and it's pretty good quality.is it actually gen5? and does it do 16x gen5 with 5090?
cool. thanks! i'll measure the hole spacing, and might order one thenYes it does, and it's pretty good quality.
I know it's a bit old, but I've been rocking a bykski block for several years now and it's been every bit as good, if not better, than the EK ones I used to buy. I will be actively seeking Bykski for my next upgrade.... when I can afford it!There is nothing wrong with Bykski blocks. I had a full cover one on my old 3070 and the quality and performance is top notch. Don't be put off just because it comes from China. Mine was received 8 days after placing the order for a much cheaper price than other manufacturers.
