Hi,
I have very recently got the itch to do a small soft tubing water cool build after a hiatus of 20 years, and although I still remember the basics a lot has changed, so I am seeking some much-needed advice please?
I have in mind a small mini-itx build and being a second desk pc, it does not have to be super powerful. It is kind of replacing a laptop that I currently use so was edging towards a mini itx build with a dvd/rw drive (I know this sounds a bit odd) and have discovered the Fractal pop mini (the mini-itx one) hasa 5 1/4 space at its front whereby a dvd can be installed.
Has anybody here used this case for a water-cooled build?
In the past couple of weeks I have obtained so far via auctions some various EK compression fittings (13/10) and today have won a used EK SE 240 radiator. I would like to water cool both the cpu and the gpu so was thinking -
- one 240mm radiator at the front of the case
- one 240mm radiator at the top of the case
- cpu block
- gpu block
- D5 pump/reservoir (combo)
Does this sound about right ?
My other questions are -
- I see a lot of d5/reservoir combos being quite expensive (used) - Would it be cheaper to buy a standalone D5 pump and then search for a small reservoir to fit the pump? (are all D5's the same, and do they all fit reservoirs that state compatible with D5 pumps?)
- All the compression fittings that I have received only have O-rings on the screw part of the connector - is this normal, do they not require O rings that connector side ?
- Apart from pressure testing a loop, is it good practice these days to run the loop outside of case/build for a few hours or are compression fittings that reliable that once pressure checked you are guaranteed safe ? (the last water cooled build that I did I used Danger Den parts, jubilee clips etc....)
- Are there specific type fans that I should use for the radiators?
- I saw a Youtube video whereby the host was recommending purchasing a temperature sensor and a mini-itx motherboard which has an onboard sensor connector (he mentioned good Asus boards have) so that the fans can be controlled via the temperature sensor of the water rather than cpu temperature - how many boards have this and do people here agree with this statement?
- I wanted to post in the Wanted section but thought I should get some help and advice so as I know what I should be requesting.
- Anything else that I am missing or should know?
Thanks in advance for help.
- cpu block
- gpu block
