[The Ocular Migraine: {Dev Mode} Master Control Program] Free and Open Source Quest Utility App
20 Apr 2015
Summary of Features:​
  • ADB permissions SURVIVE a REBOOT. PC is only required for the initial installation.
  • Change Headset Resolution.
  • Change CPU level (0-5), set as static or dynamic.
  • Change GPU level (0-5), set as static or dynamic.
  • Change Fixed Foveated Rendering level (0-4), set as static or dynamic.
  • Create detailed custom resolution profiles for games which can be selected to be AUTOMATICALLY applied to that application or game upon launching that application or game (like Quest Games Optimizer does).
  • Backing up games, which includes the APK, OBB files if any, and data files and folders located in /sdcard/Android/data/.
  • Restore game backups after moving them to your PC by using the included bat file in the backup folder.
  • Restore game backups directly from the headset backup folder.
  • Modify detailed recording settings such as bitrate, resolution, frame rate, rendering area, recording eye, with the option to save them to a custom recording profile which can be loaded for recording different applications and games.
  • Invoke recording with STEREO AUDIO on the Quest 2 and Quest 3 (maybe Quest Pro?)!
  • Video Editing. Because the Quest notoriously has problems with out of sync audio in it's recordings, you can adjust the audio offset and speed/tempo (stretching or compressing the audio) along with the start and end trimming of your video.
  • Inject 3D metadata into your 3D recorded video making it ready to upload to YouTube.
  • Set redirect/shortcut apps to launch apps from UNKNOWN SOURCES via the main menu so you don't have to go into the UNKNOWN SOURCES section.
  • Set Start Up application, for example to launch a third party launcher upon reboot. On my Quest 3 I have my start up app set to Lightning Launcher.
  • KIOSK MODE: Set an application to be the only application that can be launched and PREVENT the user from EXITING that application. This mode is password protected.
  • Access Control Lists: Create a black list or a white list. Enabling one list disables the other.
  • Web Server: for file sharing and uploading via http. You can select which folder you want to share over HTTP. You can also enable UPLOADING to your headset over HTTP. Both of these options are independent of each other.
  • Install OVR Metrics Tool and display overlay performance statistics for performance evaluation of Game and Recording profiles.
  • Install and launch SideQuest
  • Install and launch F-Droid
  • Install and launch File Manager +
  • and more...
GitHub Guide is HERE.
Latest release is HERE.
I've been using this in beta for a while, just to record 4K and 4K stereoscopic 3D on the quest 3. As you can see from the blurbage, it has a brazillian other configurable options.
Spotted this yesterday on YT, looks amazing, and it's free! The competitor costs iirc $11. Not sure if it has this, but I really make use of the QGO's disable boundary feature, because it still allows passthrough footage to be recorded without the black background. Not sure if this new app has that feature.
All, I would say is to install it from github following the instructions. It's on the sidequest site and can be installed onto the headset via PC or through the mobile sidequest app, but there are missing permissions to overcome and the sidequest installs don't work.
How does it compare to QGO (if u own this)? I know it's free which is a major bonus of course. I have had value from the QGO tbh.
I've also got QGO and there seem to be more options on the Oculus Migraine app that allow you go deeper into the workings off the Quest. Some of features I won't use or have a need for, but I may come in handy for others.
