*** Car Wash / Valet / Detailing Thread ***
Also removed the glass coating today on the ID.7
I’d used the Angelwax one.
In the video you can see that it’s still repelling water but it’s just not as zippy as Ultra Glaco or Gtechniq.
Half removed with Bilt Hamber Review first. It’s really really good stuff - didn’t find the glaco roll on removes existing coatings that well but the Bilt Hamber stuff munches anything on the glass.
Completely hydrophilic compared to the half which still has Angelwax on it.
Bought some stuff - come at me! :D
not heard of them before, let us know how you get on
do a see a compressed can instead of a spray bottle ? ;)
Just watched a YT review, appears to be decent stuff.
That insect remover looks decent, specially in this bloody heat after a spirited drive around the country roads!
A very quick review (I'll post some pictures etc when I'm back near a pc) but used these yesterday as part of a very quick wash.
Snow foam - didn't foam that much and dwell time wasn't great, however seemed to work pretty well, smelt good and was bright green.
Insect remover - better than AG's version that I normally use, spray bottle design is also very good (much better than AG that leak if you are too vigorous). Will likely go back and grab another couple of bottles.
Wheel cleaner - ironx style colour changing - ok but not anything special but cheap enough that it's probably better value than almost anything.
Tar and resin remover - excellent stuff. Always struggle with black dirty deposits on the bumper and bootlid above the exhaust on my white mini - a quick spray of this and wiped straight off with a microfibre cloth. Used hardly any as it's an aerosol rather than a liquid spray. Definitely recommend.
Bearing in mind these are all 2 for £6 in Lidl at the minute so some great value to be had.
(Be interesting to know which company actually made these for Lidl, as pretty good on the whole)
Previous owner used to smoke in one of my cars.
Cleaned the ash tray with boiling water multiple times but it still looks a bit ashy (grey)
Any ideas? It's just a black plastic ash tray.
Have you considered about replacing the ash tray ?
look on YT to see how its done, it could be easy to do
replacement sprayer for touchless & weeds/moss/fence - ultimate finish touchless was £7/L in bigger ultimate finish order need to spec out economic places to buy it.
