Hi Vince, I have been watching your Ayaneo updates with interest. Unfortunately I have a Geek 1s with post issues. The majority of the time it will turn on (lights and fans come on), but the screen stays blank. Every now and then it will post and work absolutely fine, but as soon as I restart or turn it off it won't post again. I suspect it might be a corrupt bios, but it's odd that it works every now and then... Do you offer a repair service and if so, is this something you could take a look at?
It will be very likely be that the SPI Nor is failing and has reached the limit of its endurance. What you are describing is exactly how it starts and it then gets to the point where it just point blank refuses to read the NOR. Got a pic of the geek 1s? It's absolutely something that I could put right for you. Whats the betting it uses the same NOR? I have chips on order from China that should be here next few days, in the UK the chips are about 15 quid a pop delivered but from China its just a few £ a chip. The real magic is in having the Xgecu TL-56 which is one of the few programmers that can program this chip.
The more i look at these the more I think they have QC issues with the chips they are using. Stands to reason really as I have one chip here (brand new) that kinda works but will never verify its write. I wonder if they are just letting these chips through. I also think there is a very real possibility that they are doing something in software which is causing excessive nor writes. ive now dissabled auto tdp adjustment and some other settings on mine as im not 100% convinced that the firmware isn't causing excessive nor writes. Something im going to look at is if there is a same package nor chip with higher endurance and the implications of swapping the chip out.
Edit: Also worth noting that I did end up having to change the bios chip on mine for a new one. I did get it working again by reflashing the chip they sent it back with but it failed 2 days later. Im a few weeks in now with the new chip and its been fully reliable with no issues. The white one is also working without any issues.
Short answer is drop me a message and Id be happy to fix it for you
Also our little repair thread hit a milestone... 3k replies and 200k views
