Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I never actually finished BOTW (done 2 of the beasts but explored most of the map) and only played the intro to TOTK lol
There undoubtedly will be a redesign at some point, but if it's anything like the OG Switch you'll be waiting at least 2-3 years.I didn't play the latest Zelda on og switch nor Mario Kart so I'm tempted. Holding out to see what the screen is like as no doubt there will be a revised model at some point when lots more titles are released.
Yes. It will be nice to see them in higher resolution / faster frame rate. But I've finished both BotW and TotK and spent hundreds of hours in them so I've no real desire to start afresh despite the upgrades.I didn’t play my switch 1 much, but I’ve decided to give the switch 2 a go.
Do you think the switch 2 versions of games will be worth it?
I never played the Zelda’s so will pick them up at some point.
Do the switch 1 versions stutter?Yes. It will be nice to see them in higher resolution / faster frame rate. But I've finished both BotW and TotK and spent hundreds of hours in them so I've no real desire to start afresh despite the upgrades.
Yes.Do the switch 1 versions stutter?
Ah really, I didn’t realise.Yes.
Sorry I might have been unclear. The Switch 1 console stutters a lot with BOTW/TOTK but it's not game breaking. If you overclock the Switch it improves significantly.Ah really, I didn’t realise.
Now I just got to hope I find stock somewhere![]()
Ah OK, thanks.Sorry I might have been unclear. The Switch 1 console stutters a lot with BOTW/TOTK but it's not game breaking. If you overclock the Switch it improves significantly.
The Switch 1 game running on the Switch 2 without the upgrade is an unknown, it shouldn't stutter as the hardware is so much faster.
Does this apply to physical version also?Upgrade is only £8 so cheaper than buying the Switch 2 version.
As far as I'm aware yes.Does this apply to physical version also?
Yes, but only whilst you have the subscription active ( just adding this for newcomers ).Zelda TOTK/BOTW upgrades are also included with the online + expansion pack subscription.
I might as well pick up another 12 months for £28.Yes, but only whilst you have the subscription active ( just adding this for newcomers ).
