My Apple Migration Experience
20 Dec 2004
I was kinda waffling on the MBA and iPhone threads, so thought I'd just make one thread to waffle.
So it's been a week now since I switched to Mac.
For context, the last time I owned Apple hardware, it was an iPhone 5, and a Core 2 Duo Macbook Pro in around 2011. I've been a windows and Pixel man for the last 10-15 years, with a bit of a Windows Phone diversion for a while (RIP).
I am not a software idealogue and don't care about open source ethics or any of that stuff, I just care what works.
So, I've been in game development for the last 12 years, which is pretty much a closed shop Windows business, so it was never feasible to switch. I never entertained iPhone without Mac OS because iOS was always a pain in the arse with non-Apple stuff when I used it in the past. So I have ended up working not in games, and doing quite a lot of web technology stuff, cloud, AI things, so platform agnostic.
I needed a new laptop for the new job, and initially just went for my default, which is a Thinkpad, probably an X1 Carbon, but got bogged down looking at different specs, various T and X models. Then I looked at Framework laptops which were quite appealing, as you can stuff them with loads of memory and disk for peanuts.....but ultimately, there aren't any laptops out there that can match the M4 Macbook Air, for anything. Screen, battery, performance, build, trumps everything else on paper, so I decided to take the plunge and give Apple a try again.
Got a 15" Macbook Air with 24GB memory, 512GB disk. £1439 I think the final price. After using it for a weeks, my pros and cons :
Pros :
The OS is pretty good now. I wouldn't say it's better or worse than Win 11, it doesn't get in the way and lets me get on with things, so all fine with me.
The screen is amazing.
The battery life is absolutely gob-smacking. Like re-defining what a laptop is. It's just a computer that is portable, without the compromises. Amazing.
The fact it is passively cooled is insane.
The performance is ridiculous, I installed da vinci resolve studio earlier and editing a 4k video on it while sat in the garden. Didn't break a sweat.
The fact it is passively cooled and can edit 4k video and do it without monstering through the battery....did I mention it is ridiculous?
Keyboard and trackpad are very good.
Plugged a USB-c dock thing in to connect to my external monitor and my DAC, webcam, printer. Everything just worked.
Cons :
I had to install a 3rd party app to have mousewheel and trackpad scroll with different invert settings
Text rendering in Mac OS on normal DPI external monitors is absolute ass.
I've basically switched to the MBA as my main PC now, just connected to the dock. Overall the MBA is an incredible bit of technology, and I was that impressed that I ditched my plan to upgrade my Pixel 7a to a 9a, and got an iPhone 16 Pro instead.
Kinda got used to that now.
Pros:
Hardware is nice, well finished, nice to handle.
Screen is good, although I don't really care for high refresh rates, not something that bothers me.
Security, FaceID, integration with Microsoft Authenticator and passkey handling is all really good and miles better than Android. Massive plus.
Switching over all my apps and stuff has been pretty painless, no issues, just install iOS version of things and login.
Having iOS let me login to apps with passwords which I store in MS Authenticator is great. I never got that to work on android.
Camera is pretty amazing.
CarPlay and Siri are just OH MY GOD so much better than the absolute festering pile of turd that is Android Auto and it's voice controls. It just works, it hears better, it does what you ask it do. The interface is better. Apple Maps UI is better. The whole display is more responsive. I haven't found any bugs with it yet, while Android Auto is and continues to be plagued with issues. Massive plus for Apple.
The iOS versions of many apps are actually significantly better than the Android equivalents, I guess down to the smaller range of hardware/software targets.
Cons:
Battery life is just OK.
'Magic' camera bar thing is just a bit naff.
Very niche thing here, but I have got used to dozing off at night listening to audiobooks playing on my phone, very quietly. The minimum step on the volume buttons is quite loud. This could have been a deal breaker, but I realised you do have finer control of the volume if you drag the control on the screen, phew!
So overall, I'm really impressed with it, and don't see any chance that I'll sell this stuff and go back to Pixel or another laptop.
However.
I think I will probably keep my Windows desktop for now. I do a lot of heavy video editing which makes a lot of use of AI upscaling which needs a lot of GPU grunt, and I'm a bit reluctant to spill the kind of cash required to get similar performance to an nVidia GPU in the Apple ecosystem. When I was editing video the MBA earlier it was just short videos that didn't need upscaling. I frequently edit video that take 3hrs to render on a 4070, pretty sure that will be more like 12 hours on the MBA, but I need to try once Da Vinci Resolve 20 is out of beta.
I'm a bit torn with my monitor, it's a 5120x1440 ultrawide, which I really like, but the text rendering on Mac sucks. I think I'd rather spend a chunk of change on getting a couple of 27" 4k monitors (Dell U2725QE?) to get decent DPI and scaling, than splurge on a Mac Studio or something.
Anyway, that was a lot of waffle. Overall, super happy with my switch to Mac OS and iOS. So much nicer and painless compared to when I last tried it. The Macbook Air M4 is genuinely amazing bit of hardware.
If you want even better battery performance with a small drop in speed then turn on power saving mode. I do it all the time when browsing the web and doing other non-heavy tasks.
Have you tried BetterDisplay to see if that improves your screen issues? It allows you to pick from more HiDPI resolutions than what MacOS will natively allow you to, so in theory you'll get a much clearer image with sharper text (although likely still not as good as what you're used to on Windows).
https://github.com/waydabber/BetterDisplay/releases - I'm using the free option at the moment to do that.
yeah I did try it, but I couldn’t figure out how to do anything useful with it. It was either normal native, or giant text with everything massive but nice and smooth.
Ok, any Mac OS pros help me out on this one....
How can I make my Mac Air prefer ethernet? I've just had to manually disable the wifi to get it to use my wired ethernet....
You can disable auto connect and it will still remember your network when you want to connect to it.
So I can’t just have it behave sensibly and connect to Ethernet if it’s available, wireless if not?
Had a bit of a revelation this evening, realised I can use a different upscaler setting in da Vinci resolve that is giving almost as good results with a fraction of the processing time. Doing a full video render on the MBA now and it’s looking at taking less than an hour which is plenty good enough for 25 minutes of 4k50 multicam footage.
Works for me, connected by Ethernet for internet and WiFi is remembered but set to not connect automatically. My WiFi printer is also remembered but that’s set to connect automatically.
I leave the printer powered off at the mains but when I switch it on it automatically connects to my Mac. It takes awhile for printers WiFi to initialise so it’s not instant.
Theres a shortcut on the menu bar to the WiFi settings where you just click on a known network in order to join it. I've noticed however that even if WiFi is connected as well as Ethernet it uses my Ethernet connection rather than the WiFi connection.
I can tell the difference because only my Ethernet connection is capable of gigabit speeds.
It's still baffling to me that can't just do the sane thing and prioritize ethernet over wifi.....
I have been slowly migrating deeper and deeper into the Apple hole.
Switched my browser to Safari, just works nicer with Passwords and across devices. The 2FA message integration is neat.
Just in the process of moving my documents from Onedrive to iCloud Drive, since I'm using Apple One family plan now.
Google Photos I'm still not 100% sold on. I'm using iCloud Photos and Google Photos at the moment. Maybe. can live with doubling up on that service. I do want the Apple service as the photos integration across devices is painless. Hmm.
Sold my PC last weekend, without a PC in the house since......well, the 80s :P
Waiting on my 6k monitor, plus new dac/amp and I'll be getting my Quad speakers on the desk.
I've just gone the other way, having moved from my Mac Mini M4 to a gaming PC. iCloud Drive to OneDrive is essentially all I've done. Passwords I have stored in both Edge and on my iCloud account. Wasn't a fan of the Apple password implementation on Windows. I've left my photos in iCloud as I access them on my phone 99% of the time.
Don't pretend you won't be back the second there's some shiny new kit to buy ;)
Laptops - MacBook
Desktop - PC
Phone - Whatever you fancy as 90% of what you do is within the apps that you use which are available on multiple platforms
Laptop - Macbook Pro/Air
Desktop - Mac Mini/Studio
Phone - Whatever you want
Gaming - Windows PC that's only used to play games.
Simples.
