Hi OCUK,
I built a new PC in August last year. I decided to buy an AIO liquid cooler for the CPU, after previously only using air coolers. The AIO cooler I have currently is the Lian Li Galahad II Trinity 360. It includes 3 fans which are connected to the included radiator, installed at the top of the case. The problem I am having is that my room becomes uncomfortably hot when playing games. I understand that all electronic components (especially CPUs) produce heat, and that heat has to go somewhere, but the difference in the warmth of the room compared to when I had an air cooler is quite striking to me. It was 21c outside today, but the temperature in the room where the PC is located was 28c. That was after playing a game for about 30 minutes. I have to have both windows wide open and have a large desk fan turned to the highest setting to make the heat manageable. I am wondering if I made a miscalculation, or even a schoolboy error, in buying a liquid AIO cooler without realising how much heat they can pump out into a room. I live in an old terraced house with no air conditioning. I believe it's not an issue for US-based consumers, as AC is much more common in houses and apartments there compared to the UK.
I am wondering if anyone else has a liquid cooler and have you encountered similar issues with the heat they emit? It's manageable in the winter when it's cold, but for the rest of the year and especially the summer, it's definitely an issue. The only options I seem to have are going back to an air cooler, or moving the PC downstairs to the front room where temperature is usually much lower. Neither option seems particularly appealing, but as mentioned, the current situation is proving unsustainable for me.
