You mean between a 5070 and 5060 Ti?
yep, happy to pay for whichever is the better performing
you have to call ocuk to place the order, you can't do it online
Mondayah thank you, ill do it tomorrow
tamzzy's video is much better than my answer would be.yep, happy to pay for whichever is the better performing
hopefully minimal, i've kept to parts that are in-stockand whatever potential added wait time for them to put the system together
Just to clarify, I got confused with your question because I thought you were going for a prebuilt PC. Did you actually mean my self-build?Tetras, can I ask how the two builds compare? The one shared by you and the one by Tamzzy, factoring in the upgraded RAM
Can you share the link to the article itself please.Pretty harrowing review of the RTX 5070 here
Yes indeed, but would like it to be high enough spec that I don't need to worry about upgrading for a few years
hopefully minimal, i've kept to parts that are in-stock![]()
- 111 search results on here ha so if you could please share a specific link that would be much appreciated.Yes, happy to upgrade to 9070- 111 search results on here ha so if you could please share a specific link that would be much appreciated.
Worth going for the overclocked one? https://www.overclockers.co.uk/sapp...r6-pci-express-graphics-ca-gra-spr-03984.html
The reason I included the 7800X3D is because MMOs and especially WoW tend to like them, but if that applies to WoW classic specifically, I don't know.Yes indeed, but would like it to be high enough spec that I don't need to worry about upgrading for a few years
I personally don't like the Nitro, because it uses nvidia's 16 pin, would rather have a Pulse.Worth going for the overclocked one?
Brilliant, looks like we are all set! Whilst I am here, anyone have a gaming headset rec for £150-200?
Thinking this - https://www.overclockers.co.uk/raze...ing-headset-rz04-03780100-r3m1-sp-05y-ra.html
