£1000 budget for gaming PC will this be ok?
2 Nov 2009
Building a PC for my nephew, currently has an Xbox One X so in need of a gaming upgrade. 14 years old and into the typical games (Minecraft, Fortnite, Roblox) his room is tiny so going to be plugging into a fairly old 32 inch 1080p TV which is likely to die in the next year but will be replaced by another cheap one. Normally I go for AMD but from what I can see the 14400f seems a steal at that price not too fussed on upgrade paths but for an AMD build would be looking at an A5 though and probably a 7600x which is a fairly big price jump for around the same performance (from what I can see, may be missing something). Or maybe I should just go AM4 and get a 5700X3D
5060TI 16GB is another point of contention, with the 9060XT on the way would probably go that route depending on price but if limited to 1080p I have thought maybe Intel ARC B580 12GB would probably do the job.
Any thoughts, the more ARGB the better as he is autistic and could happily spend hours just looking at the lights.
My basket at OcUK:
Total: £936.86 (includes delivery: £11.98)​
That case can fit much bigger coolers than that one like the peerless assassin,
Cheaper non corsair rgb ram (less software needed)
Better psu designed for 'fish tank' style cases with more power headroom (600 wat min for 5060ti) also its ATX v.3 spec where the aerocool isnt.
My basket at OcUK:
Total: £180.97 (includes delivery: £0.00)​
absolutely not. not for a new build.
absolute steal!
here's my take for your budget, though i acknowledge it's £50 over, it's a vastly better spec, and better yet, in stock
cheaper RAM, same 32GB, RGB, 3600MHz - don't believe the ryzen tuned marketing hype. it's the same XMP profile that intel uses.
gen 4 ssd
the case is in stock, and better still, comes with 6...yes...6 ARGB fans
cheaper cooler
5070
vastly better
psu
My basket at OcUK:
Total: £1,054.93 (includes delivery: £0.00)​
You can always sell the Doom game for about £40-£50 to cover the difference
Its a shame the bottom fans arent reverse blade like the side fans but first world problems at that price :D
7600/7600X have been edging towards ~£150 (UK prices I mean, not imports) and I'd personally take one for that over the 14400F, but by the time you add the board and DDR5 it'll be more than £30 and would need a cooler for a 7600X, whereas the 14400F can survive with the box cooler.
Not ruling it out, just already told my other half its going to cost about 700 quid........
OH! (literally and figuratively :cry: )
to be honest, with a £700 budget i'd look at getting some used parts, eg the core bundle (cpu/mobo/ram) which are the least likely parts to fail to save some dosh
I think he just told his other half it was £700 ;);););) as his original build was over £900 :D
I am happy spending the 1000, we are redoing his whole bedroom so sorting out furniture as well, its looking like our original plan wont work due to the room being tiny but new option is going to be couple hundred quid cheaper so may as well put that to good use :D
Apart from GPU think I am sorted on spec now, probably best wait till there is more info on the 9060 range before committing, fingers crossed the 9060XT falls between the 5060 and 5070 and cost the same as a 5060, can at least hope!
Just a quick update, went for the 5060Ti 16GB. Also had to make a few changes, turns out the case was far too big and needed to get something with a smaller footprint this meant new PSU as the Lian Li was just a tad too big (the replacement was 20 quid cheaper elsewhere) . NVMe drive had also gone up in price so changed that as well.
Built over the weekend, case was a bit fiddly with a couple of motherboard screws that were a challenge to get in and some very nasty sharp edges that drew blood a couple of times. Performance wise haven't really benchmarked it just played a few games to test and everything looks amazing and runs silky smooth. Its almost silent as well, ran OCCT for a couple of hours and it hit 63C and fans weren't even breaking a sweat!
With cheap wireless keyboard/mouse/headset and some cheapo lighting from China and ignoring the Xbox controller and rechargeable battery packs it came to just over £1000
Substitutes were...
My basket at OcUK:
Total: £644.92 (includes delivery: £0.00)​
