My wife just gifted me a 9950x3d and I am over the moon at the moment
I am upgrading from a 7800x3d and currently use a deepcool ls720 SE which works fine with peak synthetic loads topping out at 79 degrees C in summer weather and games reaching about 65 degrees C.
I would think that this cooler will do the job but I have also got an inch to see if I should also change my AiO as well. I know air coolers will do the job just as well and cheaply but I am a sucker for RGB (got a theme going on) so looking at an alternative 360mm AiO.
Artic freezer iii looks like a strong option but reading the reviews note that folks have issues with mounting on AMD sockets so not knowing what to expect I will probably avoid it.
Any other suggestions on what can can keep the 9950x3d under check?
Budget of £100-£250
Cheers!
!!I am upgrading from a 7800x3d and currently use a deepcool ls720 SE which works fine with peak synthetic loads topping out at 79 degrees C in summer weather and games reaching about 65 degrees C.
Budget of £100-£250
Cheers!
