CPU Cooler Advice
19 Mar 2009
Leicester
Hi guys,
Ive currently got an old Corsair AOI ?H40??? Its probably 10 years old or more but had been running well. Recently I think its starting to struggle and could probably do with replacement.
Ive got a Silverstone Fortress FT02 so I cant go for a big AIO cooler as ive only got a single 120mm fan to exhaust from with it having 3x 180 fans along the bottom of the case.
Currently running 10600k and 7800XT and I am keen to try and keep the system as quiet as possible.
Question is do I go with an air cooler or another AIO? I think probably the air cooling route will be best as having the exhaust fan without the rad strapped to it may let the heat out of the case better. Next question is which cooler as you can tell I am out of the loop on this having used this for so long. Read good things about the Thermalright Peerless Assassin but also Noctua NH-U12A.
Would welcome any advice
Thanks in advance.
what mickyflinn said
Thermalright coolers are 1/4-1/2 as much as others with similar cooling, and they are good quality too. Really can't beat their performance and value.
Odd, I just the other day switched out my server heatsink (generic AMD wraith stealth that was idling a 3600 at 60º) for a PA 120 that I got for £25.
Whilst the temps did MASSIVELY improve to 30ºC idle (though I am sure the pre-applied thermal paste of the stealth was the main culprit), the fans were awful. A really noticeable mid-high frequency hum/whir that would drive me insane as the server is on 24/7 under my desk.
So I had to drop another £12 for 2 Arctic P12s and replaced the fans. Temps are still great, but now it is inaudible above my default room noise.
