win11 pro or home
Something to consider. If you want 11, get LTSC.
I've looked into all these "debloating" scripts. AtlasOS, winutil and winaero you name it. LTSC is basically a Microsft certified debloat without any risk of stuff breaking.
I saw a windows 10 version. Is there a windows 11 version?
It might be worth mentioning that with LTSC versions you won't get any feature updates until the next LTSC release, which may or may not be an issue (probably not in most cases). Also MS don't officially support Office 365 or Teams with LTSC - you're supposed to use perpetual versions such as Office 2024, as the rolling releases might potentially depend on updates to the underlying OS which don't happen with LTSC.
Except it's stuck at 22H2 soooo, no thanks. One debloat script for me, includes all my drivers, optimisations and apps (winget or choco) - takes about 30 mins to install and includes all MSFT baselines and CIS baselines. Easy
Hooray! No more wondering what AI garbage Microsoft will feature in the next update with proper policy to disable telemetry. If what you do works for you then great but LTSC imo is just install and forget.
