Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Update on the Fosi Audio i5.
This thing is going to be amazing....I hope! Can't wait!
[td]
[td]Posted by Fosi Audio
[COLOR=rgba(40, 40, 40, 0.5)]May 22, 2025
Dear Backers,
Thank you so much for your continued interest and support for the i5 campaign! We've received many questions over the past few days, and we’d like to take this opportunity to address some of the most common ones:
1. Did you fix the sub-bass roll-off issue?
Yes, we did!
Our original intention with the i5 was to create a headphone that users could wear for long listening sessions and fully enjoy their music. That’s why we kept the sub-bass a bit relaxed to avoid listening fatigue. But after getting a lot of honest feedback from reviewers and users, we made some changes. The updated i5 now has noticeably better sub-bass, while still keeping its smooth and pleasant overall sound. We’ve already sent the improved version out for comparison testing. You can find those reviews soon on the internet.
Below is the comparison between new and old frequency response curves:
2. What did you do to fix the sub-bass roll-off issue?
The sub-bass was weak because the Velcro earpads weren’t sealing well, which caused sound to leak. We added a small sound-isolating ring around the driver to fix the leak — that boosts the sub-bass in a big way.
3. Can you still swap the earpads?
Sure. The new ring doesn’t affect pad swapping, you can still change them when you receive them.
4. Which version will be the final version for the Kickstarter campaign?
We plan to implement the upgraded version in the mass production batch, including all orders placed through the current Kickstarter campaign. However, considering that many users value the playability and customization of their gear, we’re exploring the option of making the isolation ring removable. That means while the isolation ring will be pre-installed in the mass production units, users will have the freedom to remove it if they wish to explore different sound signatures, similar to how swapping ear pads can affect tuning.
5. How long is the warranty for the i5’s headband? Can it be replaced?
We offer a 24-month full warranty for the i5. The headband, made from genuine leather, is highly durable and not prone to damage—under normal use, it should last over 3 years. In the future, we will also make replacement parts such as the headband and earpads available for purchase, should users need them.
If you have more questions, feel free to drop them in the comments below this update, we’re here and happy to help!
Thanks again for all your feedback and support!
Fosi Audio Team
[/td]
[/td]
[/COLOR]
