- 4 Aug 2007
- Wilds of suffolk
I'm thinking of joining the solar soul train and would appreciate your advice
I plan to get a Tesla Powerwall 3 and some panels for a start. My home is a terrace house, that makes a turn half way trough. So I have 4 roof sections. One South facing with room for 6 panels, South-West for 5, North-East for 3 and North for 4.
Initially I thought of getting 14 panels on the South, South-West and North-East parts and leaving the North empty, but I've been reading this thread and people seem to recommend to get panels on the whole roof.
But the problem is the Powerwall in UK comes with 3 solar string inputs, so I won't be able to connect all 4 sections of my roof to different ports.
Do you think I should just get 14, or go for 18? If I do go for 18, how can I connect them to the Powerwall 3? I was thinking maybe get the panels on one of the sections fitted with micro-inverters and connect them to the AC part of the powerwall, but not sure if that is possible and makes sense.
I think I would get the 4 on the North facing as opposed to 3 on the NE, but its a close call.
Generally we say max the roof but often talking of running 2 difference faces (3 potential with latest PW) but 4 facings is fairly unusual.
You could maybe get the NE and N facing connected together with optimisers but it adds quite a lot of cost x7 panels so might be just worth picking NE or N and doing that as a string and ignoring one small part of roof.
S6 and SW5 is a decent amount anyway.
Suggest finding one of the solar generation predictors and seeing what it throws out for N4 vs NE3 and which shows as highest probably generation.
Panels and mounting is pretty cheap hence why we say max the panels, but there are costs with installing them so its a bit of a generic saying that comes with a disclaimer of, unless installing the extra ones is too expensive vs what they will generate.
