Even more impressive hearing this. Nice oneCheers. The cowboy also called him several times after he said no and came to his door once as the roof hadn’t been sorted. He also got his so called receptionist to call him. It was two ridge tiles at £14.
Sad times M8 but don't think of it like that. Think more along the lines of having a chauffeurWent shopping with wife today - She was driving. I will have to get used to it as I shoudn't drive anymore. My manhood has now gone.![]()
chauffeurs don't scare the poo out of you. I have debated laying down on back seat with a blanket over me so I can't see anything.Sad times M8 but don't think of it like that. Think more along the lines of having a chauffeur
Or you could always criticise her drivingchauffeurs don't scare the poo out of you. I have debated laying down on back seat with a blanket over me so I can't see anything.
Or you could always criticise her driving![]()
My wife doesn't drive yet constantly tells me how to driveDivorce on the cards if that happens
Ask her if she'd rather walk....................My wife doesn't drive yet constantly tells me how to drive![]()
I doAsk her if she'd rather walk....................
Looking good.Got the trailers in place and something wasn't quite right when I bolted them to the existing steel.Turns out the bloke that welded them was on the pop during welding or the night before.
One of the trailers were 60mm out of square so I had to do some jiggery pokery to get the front parallel. He also should have used 6x2 box not 4x2.
I blocked underneath and used folding wedges as per the customers request.
Also I filled up the cavity with a lean mix and put a land drain behind the wall ready for gravel and backfilling.
Copings are next on the list. Going to prime the top of the blocks and the underside of the copings to make sure they don't pop off.
If you look at the end grain. As pieces are cut to size they will release the stresses present in the wood, often you'll see movement following patterns with the grain. Have read up on the structure of wood- things like cathedrals etc all will make the wood warp in different ways.
