Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
A new Hyundai black edition sports mower..
I may have made up the "sports" bit.
Going to attempt to paint my car :eek: This seemed to get great reviews for quality/price and should work well with the smaller home based compressors.
Paint my car, home based compressors don't go well in the same sentence :D Will you be spraying parts or the whole car?
I have seen people spraying the whole car at home with matt paint with ok results, metallic paints will take some serious skills and tent setup.
Mainly parts.
I’ve just had some repairs done to my Jeep which has resulted in matte black panels for the bonnet and wheel arch with some scratches on a door.
My plan is to get it fully sprayed next year but with building a house I can’t justify the cost right now. I’m just hoping to get a good enough job that it doesn’t look too bad for 12 months.
I figured spending £100 on a gun and then buying the paint isn’t much more cost than spray cans and should be a better finish.
I'd seen nothing but praise for the JetKVM so decided to grab one for the Home Server. Dropped the ball and forgot to select the ATX Power option so need to get one of those when they're available for retail purchase, but for now it can at least do wake on lan which does the job
Couldn't be simpler to setup, plug in USB, HDMI and ethernet and away you go. WebUI for using it seems nice and responsive even using their cloud option
