New, where from ? I might fancy a goJust picked up a Razer Edge with Kishi V2 Pro for £100! Looking forward to having a play, and at that price it was a no brainer.
Where was this? 2nd hand or new? As you say, worth a go for that price.Just picked up a Razer Edge with Kishi V2 Pro for £100! Looking forward to having a play, and at that price it was a no brainer.
It was second hand, not arrived yet. Sounds like quite a good systemWhere was this? 2nd hand or new? As you say, worth a go for that price.
It does yes, but the device is also a bit smaller and appears to be more pocketable.The Odin 2 mini Pro has a smaller screen than the RP5 though. Sure it’s more powerful on paper but what games you playing that is making the RP5 chug on Winlator ? I’m still waiting patiently for my RP5 but considering what I can load up on it when i get it.
When I get my RP5, I want to see if I can get those fringe games running good on it.It does yes, but the device is also a bit smaller and appears to be more pocketable.
Not just on paper, i've seen a few tests of it wiping the floor with an RP5. I think it was Fallout 3 and one of the Max payne games in Winlator I tried with the RP5. Still a lot better than the RG Cube I used to have.
Juiced (PS2) with another I tried on the RP5, totally unplayable even on native res. I had to change system OC settings to be able to get even close to 25fps. For the most part though, PS2 was fine on RP5 / RPmini.
Not sure if the RP devices have preloaded emulators like Ambernic. Either way, it's always better to get your own and configure as you need.Still waiting patiently for my Retroid Pocket 5 … they have just recently released the official grip for it which luckily I added it to my order. Any starter things or tips that I need to do when I get it ? I’m assuming it is an Android device with an emulator preloaded ?
Any ones you recommend ? I have seen Emulation Station Desktop Edition being mentioned a lot and also Knulli which I had running on my Brick and Smart Pro. I guess it’s another try and see which works best for me type of thing.Not sure if the RP devices have preloaded emulators like Ambernic. Either way, it's always better to get your own and configure as you need.
Daijisho for the frontend imo. Rocknix might be worth a try if you dont want to go AndroidAny ones you recommend ? I have seen Emulation Station Desktop Edition being mentioned a lot and also Knulli which I had running on my Brick and Smart Pro. I guess it’s another try and see which works best for me type of thing.
I too have an RP5 winging it’s way to me.Still waiting patiently for my Retroid Pocket 5 … they have just recently released the official grip for it which luckily I added it to my order. Any starter things or tips that I need to do when I get it ? I’m assuming it is an Android device with an emulator preloaded ?
Ah nice one and yeah I watched about half way through that video and I have bookmarked the website guide as well.I too have an RP5 winging it’s way to me.
I was going to follow this guide to setting it up, it looks quite comprehensive and has a written version too
