I built a new system early last year, and was plagued with failures to wake from sleep. If EXPO was enabled with any profile at all, it would consistently fail to wake with a memory power initialisation failure, but on cold boot it was fine, and entirely stable in use and under memtest loads. This was under multiple BIOS revisions.
Without EXPO enabled, it generally wakes from sleep ok, but fails in the same way maybe in 1 in 20 times. Since the cold boot on current motherboard chipsets are abysmally slow (the MSI MEG was over 3 minutes, even tweaked), I just put up with having EXPO disabled, and running RAM at slower speeds - the faster startup was far more important to me. I assumed it was a memory/motherboard compatibility issue (although the timings were supported on the motherboard, the *exact* model wasn't) No huge deal, just irritating.
Initially, the build was
A couple of months ago, I decided to swap motherboards again, and also swapped out the RAM (fractionally different, but officially supported on the board), the build is now
What's curious, and infuriating, is that this updated build STILL exhibits the same effect (different BIOS error code, naturally, it's now an ASUS code "11", rather than the MSI "A6"), but the same issue with failing to boot from sleep if EXPO is enabled in any way (I've tried a whole range of different profiles and speeds, all the same effect).
So it's either the CPU or the PSU. I wouldn't consider the PSU, execpt it's something to do with power according to the BIOS info.
So, any of you experienced situations like this and have any ideas how to resolve it?
Code:
MSI MEG X670E ACE
CORSAIR DOMINATOR PLATINUM CL30 (CMT64GX5M2B6000Z30)
AMD 7950X3D
Gigabyte AORUS RTX4090
beQuiet Dark Power 13 1000W Titanium
Code:
ASUS ROG STRIX X870-E
CORSAIR DOMINATOR TITANIUM CL30 (CMP64GX5M2B6000Z30)
AMD 7950X3D
On a vanilla BIOS, my 670 board was well over three minutes to boot, and my 870 a little less. But regardless of what tuning can be done to the BIOS startup, it doesn't compare to a sub 5 second wake from sleep.
