I have the optiom to buy this graphic in my country, because its the cheapest and has a good warranty
Im very sensitivy to coil whine and fan noise..
For those who owns this Card, how about the noise?? Its to loud under load?
thats goodI have watercooled my card now but ran for a week on the air cooler while I was waiting for the block to arrive. Fan noise wise I was very impressed actually, you can hear it but was not loud imo and fairly quiet hum and I could have quiet happily lived with it but I had already decided to watercool.
As for coil whine when I ran the Steel Nomad 3D Mark run I could def hear the coil whine which jumped around in pitch as the visuals on screen changed, I would say it was a little annoying. However I have been playing Doom : The Dark Ages and haven't noticed any coil whine so it seems very dependant of the particular load the GPU is doing.
2 years, but the others brand only give 1 year lmao...I had one previously and as above, I could hear the fans from 40-50% upwards but I never minded it as I playing games. It wasn't a bad whiney sound.
Mine didn't have any coil whine.
What's the warranty length in Chile? Its only 2 years in the UK which was one of the reasons I swapped to a Gigabyte.
I've got one. Coil whine is present, but not particularly bad. It's generally only audible on menu screens and in other scenarios where the framerate hits four figures. I can't hear any at all during normal gameplay or when running synthetic benchmarks. Fan noise is a bit more considerable. While the card is fine when idle or under light load, when the fans ramp up full, it is one of the louder cards I've owned, to the point the fans can sometimes be audible through headphones, during quieter sections of gameplay.I have the optiom to buy this graphic in my country, because its the cheapest and has a good warranty
Hi, thx, they all spin, how do I find the 1 that spins fastest and what do I do with it? I guess I could unplug them 1 by 1.find whichever fan you have trying to take off at 3.3k rpm
Hi, thx, will have a look, not sure what I'm looking for tbh though.Yeah, that looks like one fan going absolutely wild. Might be worth checking if the card's venting right into a sensor?
did you build this pc yourself? its not hard to find out which fan sounds like a jet engine if you get close to them, some of your fans are barely spinning and another is a rocket, either unplug them at random, find some fan control software or press on the hub of each while spinning to see if the noise decreasesHi, thx, they all spin, how do I find the 1 that spins fastest and what do I do with it? I guess I could unplug them 1 by 1.
It's a pre-built, but swapped the psu + gpu yesterday.did you build this pc yourself? its not hard to find out which fan sounds like a jet engine if you get close to them, some of your fans are barely spinning and another is a rocket, either unplug them at random, find some fan control software or press on the hub of each while spinning to see if the noise decreases
It should have idle fan stop, 95% of modern cards have idle fan stop.Hi guys, I installed a Palit 5090 yesterday, the fan noise at idle is loud, like a quiet vacuum cleaner lol, sounds like it is under full loud to be honest. I benchmarked it and the fans never got louder lol! How can I fix this? Can I fix this??
Edit - ah this is interesting and a bit strange, I've installed Palits Thundermaster GPU control software, turned off the awful RGB but strangely it reports the fan speed as 0%! All's I know is my PC sounds a like vacuum cleaner since I installed this 5090 so I assumed the GPU fans are making this noise but it says 0%.
Agreed, I suspect maybe the OP has plugged something in wrong or differently.find whichever fan you have trying to take off at 3.3k rpm
No, higher power PSUs are not noisier. Most PSUs and certainly all the PSUs that Phanteks sell do not even run their fans at idle/low load.Edit of the edit - I installed a 1200W Phanteks PSU too, could that be it? Do high'ish power PSU's sound noisier? This is at idle or light loads.
3000+ RPM isn't necessarily noisy, but my best guess is that this fan is the culprit.Edit yet again - is this relevant (screencap of HWmonitor showing fan speeds, I see FANIN1 is much higher than the others)?
Hi, as I later mentioned in this thread, I found out it isn't the GPU fans that are running at high RPM's at idle and making a noise, it's the fans underneath the radiator where the coolant circulates.It should have idle fan stop, 95% of modern cards have idle fan stop.
When you replaced the PSU, did you perhaps plug a fan into the PSU rather than the motherboard, hence it is now permanently at 100%?
How is it plugged in? I'm sure you must have connected something differently, because it wasn't making this noise before, right?Hi, as I later mentioned in this thread, I found out it isn't the GPU fans that are running at high RPM's at idle and making a noise, it's the fans underneath the radiator where the coolant circulates.
