- 19 Oct 2002
Hi there - please could I ask for your help with what is certainly a very naive question about airflow....
So - I have a Phanteks Eclipse G300A case which came pre-fitted with 3 x 120mm case fans at the front. The CPU cooler is a Phantom Spirit (which has 2 fans) and I added another 120mm fan at the back of the case as an exhaust. However - should there be an equal number of exhaust fans as intake fans? (see - told you it was naive
). If so - would I put additional fans in the top of the case or would that disrupt the airflow across the CPU cooler?
