Hi everyone,
I'm a PC building novice, so I'd like to ask for your help. I want to build my first PC, but I'm worried about the compatibility of components and having bottlenecks by ordering unequal parts. Can you please review my shoping list at the bottom and advice if all is fine or suggest what to change?
Purchase timeframe - I'd like to order all components either this or next week unless there’s a reason to wait.
Exact Overall Budget - My budget is somewhere between £2k-£3k, of course rather the bottom of the range, but can be higher if justified.
What exactly is the build for in terms of use? - The PC is to be used for gamining with my Gigabyte M34WQ monitor at 1440p resolution and some streaming as well. It will also be used as a workstation for large databases and I also want to use it for movie editing and animation.
Preferences - I'm pretty set on team Blue and Green, so Intel and Nvidia. I also prefer to have as many parts as possible from the same brand, as I feel (perhaps irrationally) that they will communicate and complement each other better. That is why I have chosen both GPU and Mobo from Gigabyte as I also have Gigabyte monitor and why most of the rest is Corsair.
What are the exact specifications of your current hardware? - My current personal PC is a more then 10 years old laptop Lenovo Z50, so I do not plan to reuse any of its components. That's why I want to build my new PC desktop from all new and maybe slightly more higher-end parts as I don't intend doing upgrades every (other) year.
Do you require peripherals? - No, I have all the peripherals I'm looking for right now.
Do you have any special needs or requirements? - No, I don't think I have any.
Here is the list of components I've selected:
Thank you.
- Case - Fractal Design North Charcoal Black Mesh Mid Tower Case - Black
- CPU - Intel Core i9-14900K (Raptor Lake-S) Socket LGA1700 Processor - Retail
- Motherboard - Gigabyte Z790 Aorus Elite AX (LGA 1700) DDR5 ATX Motherboard
- GPU - Gigabyte GeForce RTX 5070 Ti Windforce OC SFF 16GB GDDR7 PCI-Express Graphics Card
- PSU - Corsair RM850x Shift ATX 3.0 80 Plus Gold Power Supply (CP-9020252-UK)
- CPU Cooler - Corsair NAUTILUS 360 RS All In One CPU Cooler - 360mm
- Fans - CORSAIR RS120 120mm PWM Black Triple Fan Pack
- RAM - Corsair Vengeance 64GB (2X32GB) DDR5 PC5-51200C40 6400MHz Dual Channel
- Storage - WD Black SN850X 4TB SSD M.2 2280 NVME PCIe 4.0 Solid State Drive with Heatsink
Thank you.
£140
(incl. VAT)
SAVE 27%
£579
(incl. VAT)
£420
(incl. VAT)
SAVE 11%
£235
(incl. VAT)
£210
(incl. VAT)
£770
(incl. VAT)
£145
(incl. VAT)
SAVE 11%
£225
(incl. VAT)
£200
(incl. VAT)
£300
(incl. VAT)
FREE DELIVERY
