2025 models came out in the last month or so.I am about to buy my daughter either a Macbook Air or a Pro. Are there any imminent hardware refreshes that I should know about in the next few months? Thank you.
What will she be using it for? If it's not anything more demanding than basic photo editing then I would wholly recommend one of the new M4 Airs.I am about to buy my daughter either a Macbook Air or a Pro. Are there any imminent hardware refreshes that I should know about in the next few months? Thank you.
Totally agree the base model M4 Macbook Air will comfortably see them through for the next 5+ years.2025 models came out in the last month or so.
Get an M4 Mac air, job done, they are amazing bits of kit.
I’ve stopped using my desktop for editing video, the m4 air is perfectly capable of managing 100gb projects of multiple 4k50fps 10-bit streams of really difficult longGOP codec video. Now I can sit on the sofa and do my editing. On a fanless laptop…it’s wild how good they are.Totally agree the base model M4 Macbook Air will comfortably see them through for the next 5+ years.
And even then the generational improvements between M series chips has been incremental at best. I finally changed from M1 Pro to M4 Pro and if I’m being honest I probably didn’t even need to do that but it felt like a worthwhile time to do it.I'm on my 14" Mac Pro Pro chip 24G/512GB typing this. Beast of a computer and very portable. Apple will probably drop an M5 in Spring but really, so what? How fast do you need a laptop to be?
I have a m1 MacBook Pro (2021) I think, I often wonder what the main differences are between the pro and air, apart from the obvious weight difference.
I might opt for an air next time as I don’t do anything heavy on the pro, I just use it to browse, shopping, check emails and such.
Think the pro is overkill for me.
I've been thinking about the Air or Pro and for me I'm leaning towards Pro mostly because of the higher refresh rate screen. I use an M1 Pro at work and going to a 60Hz screen is a bit jarring, although the Air still has a subjectively good display.
Physically - more ports, better screen, bigger screen, active fan for cooling which means it can hold a sustained load longer. Supports more external monitors. SD card slot and HDMI out. More storage as standard
Air - The opposite of that. But the screen is still very nice. Lighter, thinner.
Day to day, the Air all day long for general tasks. I would recommend you and the vast majority of users go for the Air.
You can either upgrade the internal storage or get something external like this where I have put a 1TB nvme SSD inside. It has full size HDMI, 3.5mm audio jack, power pass through, adds another USB port and SD card slot. It even has Magsafe. Which cost about £60 total gives you 1TB storage over the £200 for extra 256G from apple and solves all the shortcoming except for the better screen (and the extra external monitor support....but this is going to affect the 0.1% of people).
I only get it out whenever I need to use it. Basically install my Steam games on there and my Lightroom library. But if I am not edition photos of gaming, i don't need to use it and the system won't fetch for it.
Great information, thanks. Yeah I think the air is best for me, I will likely wait until next year anyway, was just curious really on main differences.
