3 x 32in 1440p for competitive sim racing (4090 user)
10 Jan 2009
Now live in Scotland !
I’m in need of 3 x good monitors as Im changing my super ultrawide 57 for reasons that you can not get the right window or mirror in view. If you are a sim racer you know what I mean.
Budget is around £1200-£1400 for very good monitors. Not OLED.
I Did think of 4k and put the resolution down to 1440p but not sure about that as spotted the LG 32GR93u for just over £1100 direct or from elsewhere £1300 with 4 years warranty with ADI. but heard and seen panel issues but the ADI will cover this.
Iiyama GCB3280QSU-B2 1440p with 0.2ms for just over £750 for all 3 screens.not gsync compatible.
Alienware 32in 1440p for same price as above. (AW3225DM)
Looking for more recommendations of 32in only no smaller no bigger due to being used to the 57in (32in height) 27in to small for vertical space inside the car.
Thanks
Hi mate, the AW3225DM is curved. Are you wanting curved monitors ? The LG 32GR93U has reviewed well , maybe dropping them to 1440p as you mentioned is the way
Hi yes I don’t want curved as the Asus bezel free is a pain to like up with curved. The Bezel free is only for 27in but it can be adapted for 32in.
Don’t really want to go 4K if I can help it. Can get 3x 32GS85Q-B for £1058 delivered. This is Nano IPS HDR 10.
They sound good mate. Will you be mounting them on a triple monitor stand.
Yes mate it’s already built. All I had to do was buy the sim-labs side mounts and add them to my gtomega free standing single mount. Silly me bought 3 Vario Mounts separate and 2 already come with the Side mounts along with the Xero pivot mounts. So now need to move 2 of the Vario mounts.
Now I’m torn between the already mentioned 32GS85Q-B or the 32GS75QN-B .. the letter costing £230 less overall with only the 85Q being NANO and HDR10.
yeah the mounts help a lot with setting up tripple monitors. Could be a tough choice between the monitors as either one will be very immersive. Looking around it seems the 32GS75QN-B has been on offer selling for around £215 before
I’m glad I didn’t buy 3x at £1058 as they are now £836 for x3 from most places now. They are on here for £278.99 a monitor. Seems to good to be true when yesterday they were £449.
This is now a no brainier.
glad you got the price mate. Would be good to see a picture them set once you get them
