Read first: Build and Upgrade Advice + Template!
25 Oct 2010
Disclaimer:
Are you intending to build the PC yourself?
Please let us know what your intentions are:
(1) You are building your own PC, or will have someone doing this for you
(2) You want OCUK to build your custom PC
(3) You want an off-the-shelf PC
As computer enthusiasts, we normally recommend individual components to build a custom PC, and we can only list parts from Overclockers UK (OCUK) as this forum is owned, operated and paid-for by OCUK
We will also mention parts that not available at OCUK, if we judge that the price/performance of said part exceeds those available at OCUK
Feel free to do your own research and explore around, to find the best prices for yourself
If you do not feel confident in building your own custom PC, OCUK can build you a custom spec at a cost - please budget approx £300 for this service**, and in return, you will also receive OCUK's 3-year warranty alongside it**
If you need an off-the-shelf PC, we can also recommend OCUK's prebuilt PCs, however please note that not all of us are familiar with their range of prebuilds
** : this is correct at the time of the post 27/10/2025
Purchase timeframe
I'll start with this as we often have people looking for builds they don't intend to put together for weeks or months. Computer hardware prices shift heavily over short periods of time, let alone longer. If you're looking for a ballpark idea to save up for that's fine, but if you're looking for more detailed advice you really need to be within a week or two of purchase to gain accurate information and even then you're best off checking in a day or so prior to buying.
Exact Overall Budget
We need at least a ball park if not an exact, telling us you don't really have one could result in recommendations anywhere between £500 and £10,000, we're not mind readers. No, we do not need the prices you've concocted for each individual component, that wont offer good end results for whatever you're looking to build.
Estimated prices for gaming resolution:
1080p (FHD) = £1000-£1300
1440p (QHD) = £1800-£2200
2160p (4k) = £2400+
There is "no man's land" between each tier, if your budget falls within this "no man's land" then it's potentially too much for the tier shy of aesthetic or specialist concerns, but also not enough to jump up to the tier above.
You can either (a) spend less, or (b) spend more to jump up to the tier above.
(Current RAM and storage pricing have inflated build costs)
The above pricing was last updated October 18th 2026 to reflect current prices, please hold in mind that these have been escalating heavily over the past several weeks specifically in terms of graphics cards.
Due to current stock availability and pricing, costs have been increasing on a weekly and at times even daily basis. Manage your expectations for your build, and if possible consider purchasing as soon as is possible to avoid further expenses.
What exactly is the build for in terms of use?
Please detail your requirements, if gaming at what resolution and detail expectations? Are there any specific titles you play, or are you more of a general gaming type? Are you looking to make a workstation for productivity, assuming you are what exact software will be involved?
Preferences
Everyone has a preference, sometimes for better or worse. If you have a hard preference for AMD, Intel, Nvidia, or whatever other company please let us know prior. However, it is worth forewarning that users may offer advice at times which challenges said preferences, especially in cases where you may be greatly overspending to your own detriment or intend to purchase a flawed product.
What are the exact specifications of your current hardware?
Exact means exact, we cannot estimate what a genuine upgrade looks like for you without knowing and there is always the potential for components to be reused, allowing for more of your budget to be spent on legitimate performance increases.
We would want to know the make and model of the components as some may be able to be reused in the new build. (Inform us if you want/don't want to reuse any current components)
If you are unsure of how to find this information, please download Speccy and list the data provided under the summary section. For the power supply you may need to remove the side of your case, the make and model should be listed on the unit itself.
Do you require peripherals?
Monitor, keyboard, mouse, speakers/headset, pretty much anything that isn't inside of the PC case but is required for your experience will be a peripheral. Are you factoring these into your overall cost, or do you have a separate budget for them? Assuming a monitor is required, what size, resolution, and panel technology are you hoping for? Is high refresh rate gaming important or are you more focused on overall fidelity, or perhaps both budget allowing?
Do you have any special needs or requirements (including Wi-Fi)?
Are there any unusual aspects to your usage that might need to be taken into account such as being left handed, or perhaps some sort of disability? Do we need to account for specific hardware (this includes Wi-Fi, it's not standard on desktop PC's due to them generally being in a fixed position), software, or peripherals that could be considered non standard or at least a strict necessity?
Easy to copy-paste template following:
Purchase Timeframe:
Budget:
Usage:
Preferences:
Current Hardware:
Peripherals:
Special Needs/Requirements (inc Wi-Fi):
(My hope is to get this stickied, but any input from the regulars would be appreciated)
Preferences
Everyone has a preference, sometimes for better or worse. If you have a hard preference for AMD, Intel, Nvidia, or whatever other company please let us know prior. Please expect your irrational beliefs to be challenged and mocked.
Edit in red. But you may want to put it through chat gpt for a more polite/politically correct tone :cry:
We cannot easily estimate what you might or might not need without knowing, and there's a fair chance you could save yourself a good deal of money to boot. Exact means exact.
Edits in red.
@Gray2233 having thought about it, i think one of the sections should also ask:
(again, put it through chatgpt so that snowpetals don't get offended)
do you need peripherals?
peripherals = monitor, keyboard, mouse, speakers, headset, etc (anything that isn't inside a PC case)
if you need peripherals, what do you need, exactly?
is the budget for peripherals already included in your total budget or do you have a separate budget?
if you need a monitor, do you want a fast 1080p/1440p monitor? 4k? OLED? (note that your expectations may need to be managed, depending on the budget you have already provided)
How about a Special Needs & Requirements section? Being left-handed is the obvious one and particular positioning requirements may suggest certain cases over others
Problem with anything other than auto inserting the template into each thread is that people just don’t read.
A good few don't that's for sure, but we've actually had a fair number of people using the template lately which is nice to see.
An auto-insert for new threads in this section would be great but is likely difficult to implement unfortunately, and any sort of window pop up would probably be blocked by a lot of adblockers and the like.
