- 30 Nov 2013
Morning all
Having now purchased my first switch (an 8 port Netgear managed switch), I would like to set up 2 VLANs. One for my main PC, printer, etc. The other for my security camera (s).
The camera(s) plugs into the same switch as it provides POE. I will be viewing the camera feeds via a separate laptop (and not my main PC). The laptop will connect to my router either via wifi or i will use an ethernet cable into port 5 on the switch.
Port 8 takes the incoming feed from my router/modem/firewall.
Ports 5,6 and 7 will be reserved for the cameras (and laptop).
Ports 1,2,3 and 4 will be reserved for my main home LAN.
I don’t have any interest in being able to connect to my camera when I’m not at home and I don’t want security alerts.
I have watched so many YT videos and read articles about VLANs. I think I’ve grasped the basic concept but what I can’t get my head round is tagged v untagged.
Any guidance would be very much appreciated.
My thinking is;
Ports 1,2,3 and 4 will be in VLAN 88 (or some other random number). untagged.
Ports 5,6 & 7 will go into a separate VLAN (call it 99 for now). Assume this is untagged, as well??
I don’t want anything in ports 1,2,3 & 4 to be able to talk to anything in ports 5,6, and 7 and vice versa.
If the above ‘untagging’ is correct, what do I do about port 8 which takes the incoming connection from my router/modem/firewall?
Should it be in both VLANs and tagged??
Thanks
My thinking is;
Thanks
