- 9 Nov 2009
- Planet Earth
@humbug That is why I think AMD missed a trick! They could have made two versions of these dGPUs with different types of RAM and spanned the whole market segment under £1000 with only two dGPU designs. I wonder if GDDR7 availability is a problem or whether the validation costs were not worth it for AMD?
The RX9600XT 16GB on average consumes less than an RTX3060TI or RX7600XT,so doesn't really need massive coolers unless you are very sensitive to noise,or want to overclock.
The RX9060XT Pulse should be fine IMHO.
Could I ask a noob question in here about the cheaper versions of AMD cards vs the "higher end" ones. Gibbo has shared there are 1000 units of the 16gb Pulse 9060 xt and will be at MSRP tomorrow at least.
I've only ever bought one card, a 3080 FE. So no experience buying a board partner card
Whats the difference between the pulse and lets say a hellhound. I get that the hellhound comes with higher clock speeds out the box, but do they have the same silicon so I could just buy a Pulse and it would have the same OC headroom as a hellhound?
Sorry if this is a silly question, I'm trying to decide before 2pm tomorrow to simply buy something like the Pulse or whether it's.more the extra £ to get one of the bigger cards.
