- 6 Jan 2013
- Rollergirl
I'm looking for a new case, and would like it to be small, light and compact. Preferably ITX but appreciate I may need to go mATX.
I have a bit of a criteria / spec requirement:
1) Preferably, able to accommodate a 360mm radiator. If not able to accommodate a radiator, then a Dark Rock Pro air cooler.
2) Accommodate 3 slot GPU, length around 320mm.
Have any of you built anything similar recently?
TIA
TIA
