Aye well it was testable when I presented it at 4pm the day before. He was too busy to do it at the time of booking, so I left it with him and he said he'd do it in the morning.It can get a bit daft, but to be fair, the person presenting a car for an MOT has to make sure sure all items are working and are testable, and if they're not then don't expect a pass.
No it's not, tester is only covering his a** ie owner sells car, new owner doesn't like the car or it breaks down, first thing they do is go after the MOT station, I've seen it quite a few times, had a mate lose his licence, car was a clean mini, on the appeal against a clean mot, the car that turned up had the right numberplate on it but a totally different rusted out heap.Lol, but why even advise it though?
They are either there and working, or they're not.
Pedantry at it's finest.
Yes it is.No it's not, tester is only covering his a** ie owner sells car, new owner doesn't like the car or it breaks down, first thing they do is go after the MOT station, I've seen it quite a few times, had a mate lose his licence, car was a clean mini, on the appeal against a clean mot, the car that turned up had the right numberplate on it but a totally different rusted out heap.
*Palms faces repeatedly.I just get my tester to enter it as a mock test.
Mock test ?I just get my tester to enter it as a mock test. Fix all the faults and advisories then he just checks the work and passes it
Obviously you must have a different customer base to what we had.Yes it is.
There's absolutely zero reason to enter manual advisories, ie "long handbrake travel" or "temporary repeater lamps fitted"
Every possible advisory is on the MOT system, so the tester should use those rather than entering his own (the official advisories have a code after them).
For the tester there is every reason for him to cover his a**, it's his or her's livelihood and anything they can do to protedt it. DVLA inspectors are the police, the judges and the executioners, to fight them will cost a lot of money in appeals that is beyond a lot of testers and the station owner has a lot more to lose, there is every reason to enter manual advisory's.Yes it is.
Erm, I personally went up against the DVSA and got their decision overturned which resulted in me not having a 28 day ban, so I’m fully aware of how the system works.For the tester there is every reason for him to cover his a**, it's his or her's livelihood and anything they can do to protedt it. DVLA inspectors are the police, the judges and the executioners, to fight them will cost a lot of money in appeals that is beyond a lot of testers and the station owner has a lot more to lose, there is every reason to enter manual advisory's.
It’s a “training test” new testers can practice on, it carries no legal significance at all.Mock test ?
Not really, main dealers, independents, makes no difference, in fact main dealer was probably worse with the high cost of repairs and not a lot of trust with the public.Obviously you must have a different customer base to what we had.
I just get my tester to enter it as a mock test. Fix all the faults and advisories then he just checks the work and passes itIt’s a “training test” new testers can practice on, it carries no legal significance at all.
Based on who the OP is none of this actual happens in the real world anyway.I just get my tester to enter it as a mock test. Fix all the faults and advisories then he just checks the work and passes it
ok, obviously you didn't read this properly, Starts a test, finds faults and advisory's, changes to a "training" test, so did he log off the original test or abandon the test ? Now he does a retest ? on what test ? or does he register the vehicle for a new test and then just check the items they repaired ? Would you (JON) like to add up the points ? Quick guess I would say bye bye licence and station.
Oh it does.Based on who the OP is none of this actual happens in the real world anyway.
What in the name of the lord are you waffling on about?I just get my tester to enter it as a mock test. Fix all the faults and advisories then he just checks the work and passes it
Should ask yourself that question.What in the name of the lord are you waffling on about?
