Solar panels and battery - any real world recommendations?
The problem is he's already had 10 quotes. If everyone in the area is is offering the same sort of ballpark, then he's kind of stuck. I guess he could go further afield, but they'd likely bump the cost up to take the travelling into consideration.
He's had a better quote since:
Which is broadly in line with where I thought was reasonable.
21 x Aiko 460w all Black panels with 30 year output warranty
Hanchu 6kw inverter with 12 year warranty
Two Hanchu 9.4kw batteries with 12 year warranty
Hanchu gateway to provide power in the event of a power cut.
Scaffolding to Two sides
Napit electrical certificate
HIES insurance backed warranty
MCS accredited install
£13600
I’m on D0.616 A0.616 and the battery is on 0012 but it’s an AIO which uses different software.
Edit: my gateway has an update available but it’s all rucking rock solid so I’ll probably just leave it as it is.
I've attached an image from the 5th below where I had slightly less generation so more of the battery was used - it was down to 90% before charging over the course of the day. Fox reckons 0.1kWH for the day and Octopus reckons 6.7kWh. I don't understand how that's possible if I'm not anywhere near the minimum discharge for the battery.
host photos
The load is pretty much matching your solar production on there so the CT clamp is not reading properly or is in the wrong location. If the inverter cannot correctly see the grid and house load it won't use the battery. It'll charge up from solar still as it knows the SOC and solar coming in but that's about it. The drop in SOC is just what it is using to keep the BMS and inverter awake at night.
Bit of an update of this - after a lot of chasing, Eco Renewables finally sent an engineer round who found that the CT clamp had been installed before the meter, plus there was an intermittent fault on the CT clamp cable. Both issues have now been fixed so things are working as expected. Eco Renewables were excellent pre-sale and during the installation but I have to say the aftersales has been poor so far.
Our export has now been correctly capped at 3.68kw but still waiting on getting our approvals etc so we can get our export tariff setup. This has taken much longer than I was expecting tbh, pretty sure we'd have got it sorted by now if I'd just done it myself.
Yeah before I deleted fb I was on the owners group and it seemed like the battery updates didn't have nearly so many issues as inverter updates.
I'm on 3020 for my 9.5kWh and it works perfectly now with much more relaxed cold temperature derating than the 3017 that shipped with the battery.
Very much seems to be a case of if you don't have any particular issues, don't update
Ah ace!
I got this from Future Proof. Clearly room to haggle
Were you happy with the install?
£13600
Just one (smaller) inverter?
No wonder its cheaper as that reduces the complexity, and there isn't that much cost difference between inverters irrespective of size in most cases.
Also no mention of bird netting
Well my givenergy battery firmware is cooked. Modbus / TCP connections not working. Battery not charging at all either via solar or any commands given. Ugh. Waiting for GE to fix it. I wish I hadn't done the firmware upgrade now despite it notifying me every time I logged on.
I have updated my firmware once since getting my inverter battery, it's a gen 1 AC inverter, the firmware that was on it was well outdated, I'm sure it was the basic one that came on the hardware.
I must admit I was pretty hesitant to do that one.
The update failed twice but it didn't break anything, worked on the third time, I did that about 6 months ago and I don't think I'd ever risk it again.
Yeah same situation as me. I'm not doing it again once it's fixed.
Good Evening Solar Experts!
Install done yesterday and all went well, up and running in about five hours. I got my DNO letter today along MCS Certificate. Today was a good day for generation and I could see that the spare juice was being exported back to the grid. When I sent over all my details to Octopus for the Outgoing Octopus, it suggested it would be about 6 weeks to set up etc.
Not that this is a deal breaker but what happens to that excess going back to the grid for the next six weeks, is it essentially my free gift the to the Solar Gods until I am set up for export?
yes....
I have a Powerwall 3 (for which I have DNO approval and 5.5kw export limit) and I'm adding solar panels. The installer I decided to go with is saying that no G99 application is needed. But in the G99 regulations, I found that Section 5.2.2 states: "Where a Customer intends to modify an existing Generating Unit or add additional Generating Units, the Customer shall notify the DNO of the proposed changes."
Do you think it can be done without notifying the DNO, or do I need to wait for permission before installing the panels, or is it enough to send a notification after the panels are installed?
The section you found seems pretty clear.
The generating unit is the inverter not the solar panels so if you are not modifying it (by changing its output) or replacing it, I’m not sure what the issue is.
I agree with your installer, no G99 is required.
Think about from the DNO’s point of view, they don’t care how many solar panels you have, they care about how much energy you could put on the grid at any one time. They have given you permission to install a power wall with 5.5kw export limit. Absolutely nothing is changing in regards to the powerwall and its export limit.
