- 22 Feb 2014
Just moved my PC from W10 to W11 (clean install)
34" ultra wide 3440 x 1440
everything is smaller.
I booted back in to the W10 install to check and display scaling was set to 100% but everything looks ok (bigger)
If I set display scaling to 125% in windows it doesn't work properly and quite a few programs and dialogue boxes are blurred and i can't work out what is more annoying at this moment in time, blurry progams or tiny text/icons
some things can be changed manually, but others can't (bookmarks bar, title bar, taskbar icons, windows context menus, general text in windows)
is there a solution I am missing ?
I have windows 11 on my PC at home and didn't notice this issue, although possibly I have enabled display scaling on that (i'm not at home right now to check it), its using an Odyssey G9 49" super ultra wide @ 5120 x 1440
I also want to use a program called windock and it is completely broken with display scaling turned on
