You dump fuel and other contaminants out.  The viscosity of the oil is back to where it should be so may feel better. Also oil filter new and unblocked so arguable better oil pressure. Helps variable timing systems etc run properly.
			Just for the lols, this is from a car we had in a while ago that had some issues, one of which you may possibly be able to see..
That filter and what was once oil is rock solid.
Strangely enough the car did perform a bit better after actually having some fresh oil in it.
These two posts are the same thing.I change the oil every 5 years
You're not fun at parties, are you?No, the car I pictured hadn’t been serviced for 40K and had a thimble full of what used to be oil in it.
Pretty sure that thing killed Tasha YarJust for the lols, this is from a car we had in a while ago that had some issues, one of which you may possibly be able to see..
Sounds like an old 320i I had, every 1k miles was about 1L of oil. Had leaky valve stem seals.Just buy a car that burns loads of oil and you never have to worry about changing it, just keep topping it up.
I once had a Sierra that consumed as much super-budget *Motorway 20/50" as it did fuel
An RX-7 fits the bill perfectly.Just buy a car that burns loads of oil and you never have to worry about changing it, just keep topping it up.
Only if you drive it like you should! I deleted the OMP on mine and mixed oil into the fuel instead.An RX-7 fits the bill perfectly.
