- 24 Dec 2006
- GB
Car shudders on braking. New discs/pads all round or more to it? Car is 2015.
Take it to a MOT station and get them to pop it on the roller brake tester
They’ll soon know where the problem is.
It does.That's done a low speed, I really doubt it would show anything.
how?It does.
Not all at, the rollers run at 5mph and it’s more than enough to pick up fluctuation/grabbing.Interesting. I suppose it would need more poewr if the disc is warped.
I don’t think he’s had new discs yet.Unlikely for brand new discs though...?
how?
Good call. I don’t have a press to get the old bushes out and then the new ones in so may have to change the whole wishbone. I’m having difficulty seeing which one’s I need as there are several![]()
Check your lower control arms first, before you spend any money, its a very common fault, considering the age of your car they're most likely gone. I put strongflex polybushes in mine, night and day difference.
