Motherboard IGPU on?
28 Jan 2011
Hey guys,
I was getting some weird things going on with my pc, keyboard not being detected, slow boot times etc..
was close to doing a full W11 reinstall, but i thought before that i would try resetting default settings in the BIOS first. Now, the system seems much better, lost some game stuttering I was getting before!
The only thin I want to change is the fan curve again on the system fans. As its been reset, the IGPU is active atm along with my 5090.. is this OK to leave on running together?
Leaving the igpu on is fine but I personally turn it off so all things related default to the 5090.
Sometimes you may be asked to choose which output you wish to use so turning this off negates that.
Ah I see. If it’s ok on I will leave for now. Monitor it and make my decision then.
Hey guys,
Is your BIOS up to date?
According to to task manager my usage of ram is around the same as it was without the igpu.
What about Hardware Reserved?
