I've got my Asus TUF Gaming GeForce RTX 5090 32GB arrived at home May 13th.I got it picked up a price of 2455€ from a local store of ours. This is totally silent when maxed out gaming 4K 144Hz monitor and zero coil whine. TUF cooler is very good to keep it cool under high load when everything is taken out of this bad boy. I have played yesterday Indian Jones and the Great Circle everything in full graphics with Supreme settings, without using Frame Gen 4 so whole Frame Gen was disabled. Max peak temp was all day long gaming 79C.
My full PC setup specs what I have and also few pictures from whole setup.
CPU: AMD Ryzen 9 7950X (16c/32t) Delidded Direct-Die Cooled
- Thermal Grizzly Direct-Die Frame
- EK-Waterblocks EK-Quantum Velocity² D-RGB - AM5 Block
Custom loop water cooled CPU, EK 360mm and EK 240mm radiators with EK Pump.
(EK custom loop watercooled Delidded CPU with Direct-Die solution used with
Thermal Grizzly Conductonaut Extreme liquidmetal)
Motherboard: MSI MAG B650 TOMAHAWK WIFI, ATX
Memory: G.Skill 32GB (2 x 16GB) Trident Z5 Neo, DDR5 6000MHz, CL30
Graphics card: ASUS TUF Gaming GeForce RTX 5090 32GB GDDR7
Power: Seasonic PRIME PX-1300 ATX, Platinum 1300 W
M.2: WD Black SN750 500GB NVME and Samsung 980 pro 2TB NVME
SSD: Samsung 860 EVO 2TB
HDD: Western Digital Black 1TB and Western Digital Black 3TB
Case: Corsair 1000D
Soundcard: Sound Blaster Zx + DAC
Headset: Beyerdynamic DT 1770 PRO MKII 30 ohm Closed-Back Studio Headphones
Mic: HyperX Quadcast + Rode PSA1 Studio Arm
Keyboard: Corsair: Corsair K70 MAX RGB Magnetic-Mechanical Gaming Keyboard
Mouse: Corsair Glaive RGB
Mousepad: Asus ROG Sheath XL
Monitors:
#1 Samsung Odyssey G7 S28AG700 28" 4K UHD 3840x2160 IPS 1ms @ 144Hz
#2 Asus TUF Gaming VG27AQ3A, 27" QHD 2560x1440 IPS 1ms @ 180Hz
Image RTX-5090-Kuva-01 in the Jarppak's images album
ibb.co
Image RTX-5090-Kuva-02 in the Jarppak's images album
ibb.co
Image RTX-5090-Kuva-03 in the Jarppak's images album
ibb.co
