Caporegime
- 22 Oct 2002
- Boston, Lincolnshire
Can atmospheric pressure play a part in a plane like this seemingly take a lot of runway and then suffer once airborne.
I'm asking as an armchair expert only.
Only really if you are flying under a cumulonimbus cloud or even more stupid within it. You can get downdraughts which equate to several thousand feet per minute. There have been accidents before where planes have flown through these on approach only to be pushed into the ground and game over. Even jets.
Every time you fly you always try and take off into the wind and every flight will be flight performance tested using the POH (Pilots operating hand book) plus local airfield information or computer based with jets.
Once you have all the required information you can work out how long your take off run will be (TORA or TODA) and your accelerated stop distance (ASDA) which is the distance from accelerating to V1 (The point of no return) then to stopping.
