Caporegime
- 13 May 2003
- Warwickshire
Hi all
I'm in the middle of a hall stairs and landing renovation and the next job is to move the radiator from where it was on the right with the exposed white pipes, to the small stud wall where it's hanging in the picture below:
This frees up the whole right-hand wall and should look much better. The rad is nearly 7,000 BTUs so easily enough.
The floor is some kind of concrete screed so I'm thinking about using a grinder and an SDS drill to create channels for the pipes.
What is the best method here? Am I best using single runs of plastic rather than copper? What should I fill the channels with after I run the pipe? Does the pipe need to be sleeved or otherwise protected? Clips essential? Any other considerations?
Many thanks.
Many thanks.
