- 14 Nov 2002
- Under the Hill
Painted the garage, fitted a new receiver to the garage door.
Not necessarily a man job but as it's Father's Day me and the wife had the 2 grandchildren so our daughter and her partner could tidy up the house before they went on holiday. Absolutely loved it, puke, crying, wetting and that was just the wife![]()
Yes, we all benefitted. We have an 8yr old and a 5.5month old. For the daughter she gets a built in care service for the price of a few bottles of Southern Comfort per year excluding normal present givingYeah, that's definitely a man job, good on you. Bet the kids were delighted (and the parents!)
I was going to give a thumbs-up for the jobs done, then you mentioned 'crocs'. Sorry that is definitely not man job footwearI've been doing some tidying up in the shed, which I think counts as a man job.
Also checking the tyres on the scooters*, digging out the spares and generally getting covered in dust.
I need to rinse off my crocs now, they got covered in dust and grass seed.
*The Bosch 3.6v easy pump thing is very good for mobility scooter tyres.
It's the Don's choiceI was going to give a thumbs-up for the jobs done, then you mentioned 'crocs'. Sorry that is definitely not man job footwear![]()
Ok, the little flowers have now just made them acceptableIt's the Don's choice
They've even got little flower things on them (niece/great nieces snuck off and put them every pair).
I made another box. Better than my last one but still made some mistakes. The wood was warped from the store (standard when buying from Wickes), I overcut some of the joints, and routing out the bit for the tiles was quite messy. Improvements over the last one though, the lid fits so snuggly, probably my favourite part about the whole thing.
I think I'll just keep making boxes for now for practice, they're fun to do, and much cheaper than building bigger items. I probably only used about £7-8 worth of redwood pine for this (plus the tiles I suppose, but that wasn't really necessary)
Thank you muchThese are super impressive! They look really great.
How are you attaching the bases to them?
I've still got so much to learn but for only my second box I'm happy with the progress.
If that's just your second one you're doing very well.Thank you muchI've still got so much to learn but for only my second box I'm happy with the progress.
The base is just a single but of wood cut to size and then glued in. You can see a few more of the imperfections in the joints here:
Yeah that is definitely possible. Or you could do a small dado along the bottom and then slide a thinner piece of wood into it, then construct the box around it. I need to learn more about joints and things like that for sure.I wonder if you could use the router to take out most of two opposite internal faces, leaving a ledge at the bottom, which the base could then slide down to and sit on?
