The FADEC provides electrical excitation for the resolvers....
A FADEC (Full Authority Digital Engine Control) power supply provides the necessary electrical power for the FADEC system to operate the engine. It typically involves a 3-phase AC power source, often from a permanent magnet alternator (PMA) on the engine, and may include features like programmable output voltages, current limits, and fault simulation.
Here's a more detailed breakdown:
1. Primary Power Source:
- Permanent Magnet Alternator (PMA):
A PMA is a common source of power for FADECs. It generates 3-phase AC power directly from the engine's rotation.
- External Power Source:
In some cases, especially during ground maintenance or testing, an external 400Hz AC power source with transformers and inductors may be used.
2. FADEC Power Supply Requirements:
- Independent, Isolated Outputs:
A FADEC ideally requires two independent, isolated 3-phase outputs to ensure redundancy and prevent a single point of failure from impacting both engine channels.
- Programmable Parameters:
Features like programmable output voltages, current limits, and frequency ranges allow for flexibility in testing and operation.
- Monitoring and Fault Detection:
The power supply should measure and report per-phase voltages, currents, and waveforms to ensure proper operation and detect potential faults, like a failed diode in the rectifier.
- Fault Simulation:
The ability to simulate faults (e.g., a failed diode) is crucial for FADEC development and testing.
3. Redundancy and Reliability:
- Dual FADEC System:
Modern aircraft utilize dual FADEC systems, where each engine is controlled by its own independent FADEC. This redundancy ensures that if one FADEC fails, the other can continue to operate the engine.
- Fail-Safe Design:
FADEC systems are designed with fail-safe mechanisms to prevent engine over-limits and ensure safe operation even in the event of a fault.
- Redundant Power Sources:
Redundant power sources, such as backup batteries or auxiliary power units (APUs), may also be incorporated to maintain FADEC power in case of main power loss.
4. Specific Applications:
- Commercial Aircraft:
FADECs are standard on most commercial aircraft, enabling safer, more efficient, and fuel-efficient engine operation.
- Military Aircraft:
FADECs are also widely used in military aircraft, offering enhanced performance and capabilities.
- Retrofitting:
Older aircraft are often retrofitted with modern engines utilizing FADECs to improve performance and efficiency.
In essence, a FADEC power supply is a critical component that provides the necessary electrical power to the FADEC system, enabling the engine to operate safely and efficiently under various flight conditions.
