If the FADEC fails on an engine what would happen to the engine
If the
FADEC (Full Authority Digital Engine Control) fails on an engine of a
Boeing 787-8 with
GE GEnx-1B engines, here’s what would happen:
Each FADEC has
dual channels (Channel A and Channel B). Normally only one is active at a time, but:
- If one channel fails, control is automatically transferred to the backup channel.
- So, a single-channel failure does not result in engine shutdown.
If
both channels of the FADEC for an engine fail — which is
extremely rare — then:
- The engine will typically shut down or enter a fail-safe mode.
- The engine cannot be controlled (thrust, fuel, etc.) without the FADEC.
- The pilot cannot manually override it — FADEC is a full authority system.
In other words:
Without a working FADEC, the engine cannot operate.
what is the fail safe mode and what would it do in that mode ?
Great question — let’s go into detail.
What Is “Fail-Safe Mode” for a FADEC?
In the context of the
GE GEnx-1B engine on a
Boeing 787-8, the term
“fail-safe mode” refers to how the
engine responds to a critical failure in the FADEC system, particularly if
both FADEC channels fail or become unresponsive.
What Happens in Fail-Safe Mode?
In general,
if both FADEC channels fail,
the engine cannot continue normal operation. Here's what happens in that case:
1. Engine Shutdown
- The most likely response is automatic engine shutdown.
- Since FADEC controls fuel flow, ignition, variable geometry, and other systems, no control input can be processed without it.
- The engine cannot "limp along" in a degraded power setting because there’s no way to meter fuel or control airflow.
2. Attempted Safe Configuration (if possible)
- In some cases, before shutting down, the engine may try to lock in a pre-set “safe” configuration for a few seconds (e.g., fixed fuel flow, fixed stator vane positions).
- However, in most modern FADEC-controlled engines, this mode is transitional at best — buying time for shutdown.
- The idea is to avoid damage, fire, or unsafe thrust conditions.
Why Not Manual Backup?
- Older engines had manual backup controls (e.g. mechanical throttle linkage).
- The GEnx (and most modern engines) use full-authority digital control — there is no manual override.
- So if both FADEC channels fail, the engine is effectively uncontrollable and must shut down to remain safe.
What Happens Next?
- The engine is declared inoperative.
- Pilots get an ECAM/EICAS alert (like ENG FAIL or ENG SHUTDOWN).
- The crew follows engine failure procedures (e.g., single-engine drift down, diversion, etc.).
- The aircraft can continue flying safely on one engine due to ETOPS certification.
Summary:
Condition | Outcome |
One FADEC channel fails | Backup channel takes over — engine continues normally |
Both FADEC channels fail | Engine shuts down or briefly enters fixed "safe" state before shutdown |
Pilot control possible? | No — FADEC is full-authority, no manual override |
Aircraft impact | Engine-out procedures followed, aircraft can fly safely on one engine |
I would like a schematic and timeline of how the FADEC responds to faults
It looks like I need you to be logged in to ChatGPT in order to create and share a schematic. However, I can describe the timeline and fault response process for you in detail.
Here’s a breakdown of how the FADEC responds to faults in a
GE GEnx-1B engine system:
Timeline & Schematic for FADEC Fault Response
1. Normal Operation (Pre-Fault)
- FADEC Channels A & B active: Both channels monitor the engine’s health and control all key systems, including fuel flow, engine speed, and variable stator vanes.
2. Fault Detected in Channel A (Minor Fault)
- Fault type: A temporary fault (e.g., sensor glitch, minor electrical disturbance).
- Response:
- Channel B takes over full control.
- Channel A goes into standby, awaiting recovery or reset.
- Engine operation: Unaffected, continues with Channel B running the engine.
- Pilot alert: The system might display a warning like "FADEC A Fail" or "FADEC Channel A Active" on the cockpit display.
3. Fault Detected in Channel B (Minor Fault)
- Fault type: A similar transient fault (e.g., low voltage, communication issue).
- Response:
- Channel A takes over full control.
- Channel B goes into standby.
- Engine operation: Unaffected, continues with Channel A running the engine.
- Pilot alert: A warning like "FADEC B Fail" or "FADEC Channel B Active" is shown.
4. Complete FADEC Failure (Both Channels Fail)
- Fault type: Severe failure, such as simultaneous failure of both channels (e.g., power loss, critical software corruption).
- Response:
- Engine automatically shuts down or goes into a fail-safe mode.
- Engine may enter emergency fuel control or fixed settings (if the fail-safe allows).
- Pilot alert: The cockpit will show an “Engine Shutdown” or “ENG FAIL”warning.
- The engine cannot be restarted by the crew due to FADEC failure.
5. Fail-Safe Mode (if applicable)
- Possible Fail-Safe Response: Some modern engines (including GEnx) might attempt to configure the engine to a "safe mode" where:
- Fixed settings for fuel and airflow are applied for a few seconds.
- The engine may run at a minimal power setting to give the crew time to respond, but this doesn’t last long.
- Duration: Typically only a few seconds before the engine fully shuts down.
- Pilot action: Follow engine failure and shutdown procedures.
- The aircraft can continue flying on the remaining engine.
Schematic Overview:
- Step 1: Engine Running Normally
- FADEC Channel A & B active
- Full engine control with all parameters monitored.
- Step 2: Fault Detected in Channel A
- Channel B takes control
- Pilot sees FADEC A failure warning.
- Step 3: Fault Detected in Channel B
- Channel A takes control
- Pilot sees FADEC B failure warning.
- Step 4: Total FADEC Failure
- Both channels fail → Engine shutdown or fail-safe mode initiated.
- Pilot sees engine shutdown alert.
- Step 5: Fail-Safe Mode (if engine is running for a short time)
- Safe parameters applied for a few seconds.
- Engine shuts down if no recovery is possible.
Additional Notes:
- Critical Faults: Major faults that result in complete failure are extremely rare, especially with redundant FADEC systems.
- Flight Outcome: The aircraft can continue safely on the other engine due to ETOPS certification and modern engine reliability.
If you’d like more specific details, like how each subsystem is wired into the FADEC or more advanced fault types, feel free to ask!
I would like how each subsystem is wired into the FADEC and more advanced fault types
Let's dive into the detailed workings of the
FADEC system, its wiring, and more advanced fault types. I'll also break down how the various engine subsystems are controlled and monitored by the FADEC.
1. FADEC System Overview
The
Full Authority Digital Engine Control (FADEC) is a highly integrated digital system responsible for
controlling and monitoring every aspect of the engine in real-time. It communicates with the
engine sensors,
actuators, and
other systems to ensure safe and efficient operation.
Key Components Managed by the FADEC:
- Sensors: Measure critical engine parameters (e.g., temperature, pressure, speed, fuel flow, etc.).
- Actuators: Adjust engine components like fuel valves, thrust reversers, and variable stator vanes.
- Electronic Communication: FADEC communicates with other avionics systems and provides feedback to the cockpit.
Each
GE GEnx-1B engine on the
Boeing 787 has
two FADEC channels (A and B), each operating independently. Here's how the wiring and subsystems work:
2. Wiring of Key Subsystems into the FADEC
a. Sensors and Inputs to FADEC
The FADEC receives inputs from various
engine sensors, each responsible for monitoring specific engine parameters. These sensors feed
electrical signals to the FADEC that get processed to determine the engine's operational state.
- Turbine Inlet Temperature (TIT): Measures the temperature of the gases entering the turbine. This helps manage fuel flow and ignition.
- Pressure Sensors: Measure compressor discharge pressure (P3) and combustion chamber pressure, which are used for performance monitoring and adjusting airflow.
- RPM Sensors: Measure the low-pressure spool speed (N1) and high-pressure spool speed (N2).
- Fuel Flow Sensors: Measure the amount of fuel injected into the engine.
- Vibration Sensors: Monitor engine vibrations that could indicate misalignment or damage.
- Exhaust Gas Temperature (EGT): Monitors exhaust temperature for performance and safety.
b. Actuators Controlled by FADEC
The FADEC directly controls
actuators that adjust engine components based on sensor data. The two FADEC channels can operate
independently or share control in case of redundancy.
- Fuel Control Valves: The FADEC adjusts the fuel flow to each engine in response to throttle input and other performance parameters.
- Variable Fan Blades/Stator Vanes: The FADEC adjusts the angle of fan blades and stator vanes for optimal airflow and efficiency.
- Thrust Reversers: FADEC manages thrust reversers for braking after landing.
- Ignition Control: FADEC controls the igniters based on engine speed, airspeed, and throttle position.
c. Data Communication Systems
FADEC communicates with the
aircraft’s avionics systems (like
ECAM or
EICAS) to provide real-time
status messages and
alerts about engine performance. The data is shared over a
Redundant Data Bus that helps in fault detection and isolation.
d. Power Supply
The FADEC is powered by the
aircraft’s electrical system (normally supplied by the
main generators).
Power loss to the FADEC is detected, and in such cases, the FADEC would enter
fail-safe mode or cause the engine to shut down, depending on the severity of the fault.
3. Fault Types in FADEC: Advanced Scenarios
FADEC systems are designed to
handle a wide range of faults while maintaining
engine safety. Below are some of the more advanced
fault types and how they would affect engine operation.
a. Sensor Failures (Input Faults)
If a sensor feeding into the FADEC fails, it may lead to:
- Single Sensor Failure:
- Example: Fuel flow sensor failure.
- Impact: The FADEC will use backup data from other sensors or revert to pre-programmed "safe values." For example, if fuel flow is uncertain, the FADEC may default to a conservative fuel flow to prevent over-fueling or under-fueling.
- Pilot alert: A message like "Fuel Flow Sensor Fail" might appear on the EICAS.
- Multiple Sensor Failures:
- Example: Loss of both TIT and EGT sensors.
- Impact: The FADEC would enter a fallback mode, relying on alternate sensor data or default engine settings.
- Pilot alert: "Engine Performance Degraded" or "Multiple Sensor Failures" on the EICAS.
b. Actuator Failures (Output Faults)
Actuator failures affect the engine's ability to adjust parameters based on FADEC commands. This might result in:
- Fuel Control Actuator Failure:
- Impact: The FADEC may attempt to adjust fuel flow, but the actuator fails to respond.
- Pilot alert: "Fuel Control Actuator Fault" or "Fuel Flow Error".
- Response: The FADEC might attempt to enter a fixed fuel flow mode for stability. However, performance could be degraded.
- Thrust Reverser Actuator Failure:
- Impact: Thrust reversers may fail to deploy, which is a critical issue for landing.
- Pilot alert: "Thrust Reverser Inoperative".
- Response: The aircraft can still land safely without thrust reversers, but it might require longer runway distances.
c. Power Supply Failures
If the FADEC loses power (e.g., due to
generator failure or a
wiring issue):
- Loss of Primary Power:
- Impact: The FADEC will automatically switch to backup power from the secondary system, usually from the aircraft’s battery or a redundant generator.
- Pilot alert: "FADEC Power Loss" or "FADEC Backup Active" on the cockpit display.
- Response: The engine may run at reduced performance until the fault is cleared.
- Complete Loss of FADEC Power:
- Impact: Both channels go completely offline.
- Pilot action: The engine will shut down and the aircraft will need to rely on the other engine.
d. Software or Logic Failures
A
software fault or
corrupted logic in the FADEC could lead to:
- Inconsistent Engine Behavior:
- Impact: Erratic fuel flow, variable fan speed, or unexpected throttle behavior.
- Pilot alert: "FADEC Logic Error" or "Engine Control Fault" on EICAS.
- Response: The FADEC may automatically switch to a default control mode, and the engine may run at a fixed speed or reduced power setting.
- Total FADEC Failure:
- Impact: If both FADEC channels fail simultaneously, the engine will enter a shutdown or fail-safe mode. This is very rare.
- Pilot alert: "Engine Failure" or "Both FADEC Channels Inoperative".
- Response: The engine is shut down or locked in a safe mode until the fault is resolved.
4. FADEC Failure Mitigation and Safety Features
- Redundancy: The dual-channel FADEC system ensures that if one channel fails, the other will take over seamlessly.
- Real-Time Diagnostics: The FADEC constantly monitors all components and can self-diagnose faults, allowing the crew to be alerted in real-time.
- Safety Thresholds: FADEC operates within predefined safe thresholds. If a parameter exceeds these thresholds (e.g., temperature or pressure), the FADEC will take protective action such as reducing engine power or initiating shutdown.
Summary:
Subsystem | Component | Fault Type | Response |
Sensors | TIT, Fuel Flow, EGT, etc. | Sensor Failures | Use backup values or fail-safe mode |
Actuators | Fuel Flow Control, VSV, Thrust Reversers | Actuator Failures | Fixed settings, conservative operation |
Power Supply | FADEC Power | Power Loss | Switch to backup, reduced power |
Software/Logic | FADEC Software Logic | Logic Failures, Corruption | Default mode, engine shutdown or degraded performance |
Complete FADEC Failure | FADEC Channels A & B | Both channels fail simultaneously | Engine shutdown, cockpit warning |
I hope this helps with understanding the subsystems, wiring, and advanced fault types in a
GE GEnx-1B FADEC system. Let me know if you'd like a more specific dive into any part of this!
