- 24 Dec 2006
- GB
Looking to get! What do I need?
You ideally want two torque wrenches, 3/4 upto 60Nm and 1/2 that goes up to 210-310Nm.Jobs to be done are brake disc/pad changes on BMW 330d F31. ZF8 transmission service.
Don’t know what I need to buy. Length? Drive type?
Never had a torque wrench.
Is that a thing? I use cheap torque wrenches on my MX5 and to be honest I was impressed that I was even using themAlways remember to unwind it completely after using it.
Is that a thing? I use cheap torque wrenches on my MX5 and to be honest I was impressed that I was even using them.
It literally says it in the manual, lol...Is that a thing? I use cheap torque wrenches on my MX5 and to be honest I was impressed that I was even using them.
I would hope the Venn diagram of "people who actually torque things to spec" and "People who read the manual" is pretty close.
It is very easy to put your wrench away and forget to take the tension off though![]()
Such a simple task, yet I've seen some of my mates fail miserably when I offered to teach them.Also technically you are supposed to have them calibrated once a year - though mine went about 3 years and was still within spec.
Not to put anyone off - everyone has to start somewhere, etc. but changing discs and pads without knowledge of the tools required is jumping in the deep end a bit.
Plus the risk of doing it wrong - it's not fun driving your car around wondering if your brakes will fail because you missed a bolt or bled them wrong.It is one of those things which is easy once you know how, but not trivial to jump into blind.
If something is wrong, you can usually tell when you take it around the block, you always do slow speed test before taking it further.Plus the risk of doing it wrong - it's not fun driving your car around wondering if your brakes will fail because you missed a bolt or bled them wrong.
This is a good representation how to do it properly and easily, it applies to most cars..
I usually clean the hubs and leave them as is... I give a smudge of copper grease on bits that move. My car had copper grease on the hubs, I left it on when I was changing discs. It was a bit of a test, to see if I would get brake judder - no symptoms though.I dunno - the way they are using a wire brush to clean stuff I was always told was a big no no on those parts - I usually (saying that like I do it often LOLs) use either Autoglym or Motip cleaning spray. Their use of copper grease as per the comments, how I was taught and posts in threads on here probably isn't the best either.
