Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Ok so a couple of questions. I watched a video of someone typing on the Q6 Max and is seems a bit small side ways (left to right). The guys hands looked a bit cramped. Anyone here with a Q6 that can comment? Might just have been a weird optical angle / trick of the eye and/or the guy had giant hands!
Would be helpful if someone with a Q6 could measure the distance from the left of the caps lock key to the right of the enter key so I can use my current MX Keys for reference (it's about 279mm).
Also, I have noticed a Q6 HE model that is a bit more expensive but uses hall effect switches. Is there any logical reason and tangible benefits provided by hall effect switches over standard mech switches that come on the non HE version?
HE switches are the new thing, using software you can tweak where along the down travel point is when the key is engaged. Either the very top or very bottom or somewhere in between.
I don't know about the distance of the keys as I don't have a Q6 but only the Q1 and Q2.
