That's fine, those are easy via ENA connect direct. The DNO know me at this pointnumber 2 and 3 would also need a new g99 application for bigger inverter and disposal documentation for removed inverter.
I think if I had the option at equivalent cost I would go for in roof. No risk of bird issues, no risk of wind catching panels, etc.I'm getting some building work done which will involve replacing the roof, so I thought it would be sensible to go down the in-roof/integrated panel route so I didn't have to pay for the roof tiles.
After getting a few quotes from solar providers, the quotes for in-roof panels are between £1000 and £1500 more than the equivalent on-roof solution. That's approximately the same as it would cost to tile the area, so the overall cost would be comparable.
I'm not that bothered by the aesthetics of the panels, so I'm leaning towards on-roof panels for the following reasons:
- Slightly more efficient (due to airflow underneath them).
- Simpler installation (e.g. lower chance of leaks as the roof is already watertight, more flexibility at installation time as there can be a longer gap between roofer and installer doing their thing).
- More choice (some installers only offer a certain brand and/or size of in-roof panels because they fit the trays they like to use).
- Easier to replace the panels in future (panel sizes/mounting systems will likely have changed in 10+years, so having to change the trays as well as the panels would be a much more expensive/complex job).
Just wondered if anyone thinks I'm overlooking anything?
Yes, as mentioned above, the gap immediately above the panels make a great place for seagulls to nest - I have a nest between the ridge and the panels.Just wondered if anyone thinks I'm overlooking anything?
I'd go in roof if doing the roof, just to solve this problem.
All the on-roof quotes I've got include bird proofing. Or are you saying they like to create a nest on the edge of the bird proofing?
Even if this were to become a problem, I still think I'd prefer to accept the risk if it means minimising a potential future bill (due to more expensive panel replacement).
Have you checked any option is cost effective and do you actually need an additional 26kwh of batteries?I'm after more battery and not sure of the best route.
I currently have:
1x Powerwall 3 (13.5kWh) with 30x445W panels in 3 strings of 10
1x Solax 6kW String inverter with 14x645W panels in 2 strings of 7 with Tigo optimisers
I will likely add more panels at some point (north roof at least), but I definitely feel I need more batteries for the periods where Octopus decide my rate isn't 7p.
I see 3 main options:
1. Add PW3 DC expansions, 1 would take me to 27kWh, 2 would take me to 40.5kWh. Cost about £5500 each. Can pay for them on 0% finance for 3y. Integrates well with existing battery, don't need to make any changes to my automations. Can then charge from grid at 8kW rather than 5kW.
2. Replace the Solax inverter (which gets some clipping anyway) with a larger hybrid inverter, and get 2x Fogstar 16kWh batteries. This would cost around £6k for 32kWh, and slightly more generation (less clipping), but does mean I have to manage two batteries that won't talk to each other, I would have to take efforts to make sure one didn't charge the other etc.
3. Go the insane route, copy that guy off youtube, replace the solax inverter as above, and mount a recovered Tesla Model 3 LFP battery pack to my garage wall. A lot more work but I think I could handle it, about the same cost as option 2 I think (£6k), but would get me 60kWh. Has all the management drawbacks of option 2.
What would others do?
Once you have enough batteries, adding more doesn’t increase your ROI, it reduces it.
For me, option 1 or wildcard #4, rather than the DC expansion, get another Powerwall 3 and bin the Solax inverter.
I’m all about the ease of use and simplicity where possible.
Same. So bear in mind the roof probably isn’t flat or level either.Struggling to see the alignment issue (probably photos dont really show it), and that cable, doesn't look like a new solar one to me
