Very nice! You could make a sliding sled for it if you wanted to extend its functionality. There are tons of videos online about making them. It also doubles as a fun project to use the saw forI made another box. Better than my last one but still made some mistakes.
Started the next project this week. Building a shed on the side of the house, with the intention of storing bikes in there and a fridge/freezer probably.
Particularly happy with how the flooring system is working out. I can't remember where I saw this - one of the countless youtube videos I'm sure - but its so simple and clever and quick. Basically digging small piling holes which I'll fill with concrete. Using threaded rods and washers to make sure the floor is actually level I can just pour the concrete and not care if its 100% level or not:
Good find! Yes credit where credits due, this was the one!That is a nice system and one I see for the first time when watching content from the below video creator, who I believe was once called Oakwood?
No its not a system as such in that its sold as a complete package, I bought the wood from a wood supplier and the rods from a metal rod supplier.I am looking at building quite a large deck and am looking at alternatives to traditional timber posts.
Did you buy the timber joists/bearers and rods separately, or was it all provided as part of the same system?
I have spent a few hours watching drain clearing video's lately. It's amazing what people put down the loo. I had to call one out once but it turned out to be lazy drains -These low flush cysterns just don't have the water volume and capacity to shift stuff that has just come to a halt on low drop run of pipe.Watched a chap cleared a massive ****berg from my drain, then paid him.
Let me see if I can find them...here you go: https://directchannel.uk.com/product-category/threaded-rod-support/. Think thats ok as they're not a competitor!
I personally went for m24 sized stuff as I wanted it big and to support 2x6" joists. I bought 1 metre rods and cut them down slightly (with an angle grinder) as I didn't want pilings that deep. At the base of the rods in the ground I locked a washer between two nuts, to give it a bit of an anchor in the concrete, then at the top drilled an inch into the wood to locate the rod, and sit the wood on two locked nuts and a washer as pictured. Really straight forward and so easy to ensure levels. So with regards to your project an absolutely perfect system. Its way cheaper as less concrete is required, and you can't fail to be able to level the floor/deck.
Strongly recommend a postholer as well if you dont have one already. https://www.screwfix.com/p/spear-jackson-post-hole-auger/3911k or https://www.screwfix.com/p/roughneck-fibreglass-post-hole-digger/35835 (which I used) makes digging the actual holes themselves as well an absolute breeze.Very useful. Thank you.
And agreed, the amount of concrete required looks to be a lot less. In addition for me, given the amount of supports I need (and thus holes) for my current deck design, the less digging I need to do, the better!
I will almost certainly go for something like this.
Thanks again.
