I'm heading towards my next build..
Currently I have a Lian Li O11D with a 5800x and 3080FE.. this is cooled with 2x 360 rad and 1x 280.
I have a 5090FE secured and I've been given a Fractal North FOC.. very lucky I know. I'm also planning to have a 9800X3D. I am definitely custom watercooling it all, I always do and I enjoy it.. I'm actually a fairly light gamer and no productivity but it's been a habit I've enjoyed for 20 years.
Given it's been probably 3 years since I last did a build plus having had a few good years I'm planning to go all in on this but I can't decide where to go.
For example... I understand the North will only take a 360 and 240? Is that enough to cool a 9800/5090? I'm assuming it might be on the edge/loud? That's a non starter for me.
I quite fancied getting a MORA setup (all in, see above) but to my mind mating that up to an ATX case misses the point and I may as well ditch the North, get an SFF case and have all the cooling external?
So then I started thinking about potentially the North with internal cooling and an optional external MORA.. but given then thing never moves that also seems silly.. if you need external cooling why not have all external cooling?
So.. with budget not being a consideration (within reason) and the only other real consideration being I don't want and don't really have space for a huge case.. what would you do?
		 no correct answer. Mo-Ra is end game for me. It looks great too, so i have it in a place that doesn't take much space or get in the way and adds to the room. Now i know i am set up for life for low rpm fan water cooling. In your instance, as i am Mo Ra bias now, i would say small build, and go fully external with Mo Ra. Its done then
