What GPU's have two HDMI that can output 4k at 120hz simultaneously?
26 May 2008
After seeing another thread where someone was having issues with both HDMI connected, I was curious as to what current GPU's can actually output 4k at 120hz over two HDMI outputs?
I was looking at getting either a Sapphire Pulse+ 9070XT or an Nvidia 5070ti around £700 or thereabouts.
From what I have read DisplayPort is limited to 2m lengths passive, whereas with HDMI we can run passive up to 5m and 10m with active HDMI high speed. As an example, if my sitting room PC location was connected to the TV, it's either 3m or 5m, up to 10m if using a projector too. So I would be interested in having the option of two Display Port and Two HDMI possibly. Even with the main PC living upstairs it is often connected to a TV again 5m away while also running a monitor, but currenty limited to 1080 output to a 1080p monitor and 4k TV.
My main PC upstairs usually sits on a HiFi rack in the corner, currently under the desk due to moving things around and too much tension having been on cables. Downstairs the audio racks are currently 8m away from the TV, though that may change, the wife isnt too keen on the racks and a visible PC, so the option of various long cable configurations may be of benefit.
It should not be a deal breaker, but reading about another guys problems with dual HDMI output has sort of put me off AMD somewhat, only to find I can't see any 5070ti with dual HDMI as an option anyway?
I cant answer your primary question (though I would expect any modern card with 2xhdmi to work fine) but if you do decide to go with an active optical HDMI then remember they are often directional! One port input the other output.
Had to re-do 15m of wall trunking when I found that out. ..
I remember reading that thread and found it quiet disappointing that new cards were released with that problem; from memory I think the AMD rep was saying the cards with 2 HDMI ports weren't in the original spec and the third party vendors had changed them (not making excuses for them it shouldn't have happened). I guess not many people (myself included) have two 4k high refresh HDMI devices connected at the same time so they wouldn't even notice the issue.
Almost seems like GPU vendors don't want to support HDMI and it might go the same way GPU’s with USB-C did which would be fine if TV's, projectors, soundbars etc shipped with Display Port sockets instead of just HDMI connections.
In the past I've had to have HDMI over cat6 media converters installed for school projectors mounted on very high vaulted ceilings; these days I would just go with a fibre optic HDMI cable which does away with the length restrictions, if you do a search online there are also fibre optic display port 1.4 to display port (it was listed as 4k 144Hz) cables and Display port 1.4 to HDMI 2.1 (it was listed as 4k 120Hz) fibre optic cables which should do away with the length restrictions if that helps you connect everything up.
Some of the cables I saw had absurd prices but the ones I mentioned above had mid double digit price tags depending upon length (the ones I saw ranged from 10 to 20 meters).
So far seeing Asus Tuf series 5070ti as the cheapest option at around £900. But still need to use an adapter for the 12v cable. Only found Asus Tuf and RoG options on all the Nvidia cards.
I have looked at the Display Port to HDMI cables and adapters too, which start off at reasonable prices, but seems a little bit of a minefield with complaints of VRR or HDR not working and other glitches. Basically could be spending around £60 for an adapter or cable that might be plug and play but not guaranteed?
It gets a little off putting when you start considering adapters and cables as work arounds. I was even considering a more basic 9070xt with two 8pin connectors and trying a Display Port to HDMI cable simply because I find the thought of using 8pin to 12v adapters rather ugly.
Yet still find it hard to look past either the 9070xt or 5070ti for cost and performance, the 5080 starting at £980 seems good value when compared to a 5070ti costing £900.
Seems that with Nvidia you can pay £200 to get a second HDMI port on a 5070ti taking it near to 5080 pricing. Or an extra £500 to get an extra HDMI port on the 5080. £1400 for 16gb of memory with two HDMI and a slight performance over the 5070ti seems difficult to justify, would see the point if it was more memory.
Going around in circles here lol.
For me, paying £900 for a 5070 Ti is way too much, but if the alternatives aren't any good to you, then I guess it doesn't matter what they cost.
Yeah, these adapters were fine for 60 Hz, but when we add VRR, high refresh and other features, it gets complicated.
It seems like these were always intended to use DP primarily, maybe because HDMI has a license fee, so even though they can have 2x HDMI, the standard supported config for both the 5070 Ti and 9070 XT is 3x DP and 1x HDMI.
I went through this a while ago as I have 2x LG OLED TVs as monitors and I couldn't find any adapters/cables that would support 4k 120 + Gsync via the displayport. None supported Gsync and I found one adapter that worked with 4k 120 but it was unstable (would occasionally switch to 60hz).
I ended up getting an ASUS TUF 4090 which works perfectly with both screens.
I find it odd that graphics cards give you 3 x DP and 1 x HDMI (typically) but monitors tend to go the other way with 1 x DP and 2 or 3 x HDMI.
I wish both could just agree on 2 x DP and 2 x HDMI.
From what I've read the licence fee is payable on the end product and for the use of the logo, it doesn't make any difference if the device has one HDMI port or four they pay the same fee and the only way to avoid it would be to have no HDMI ports on the device; they would still need to pay a HDCP licence fee even if they ditched HDMI and only used Display Port connections.
The real problem is that manufactures of TV's, Projectors, Sound bars etc have stuck with HDMI and haven't added DP connections to their devices but people connecting their PC's to their TV is still fairly niche compared to all the game consoles which all use HDMI.
I guess they think its more likely that someone will have 3 monitors on their desk and occasionally connect to a TV or projector than they are to connect to a TV and a gaming projector at the same time.
If you think about it though it kind of makes sense most people will only have one PC connected to their monitor but they might also have a games console and a firestick etc so they need more HDMI ports than DP.
An update to this.
A couple of things have made me pretty much give up on this dual 4k 120hz over HDMI for now. Apart from the excessive cost of getting a card with two functioning HDMI outputs, I simply was not getting on with 42" as a monitor, desk is 80cm deep, but in reality for the majority of time 42" was used the content on screen was simply uncomfortable to work with. No idea how my lad manages it.
I used some of the saved GPU money to grab a discounted 27" MSI 4k 160hz QD display as Prime deals kicked in, still to plug this new MSI monitor in as I do not have a long DP cable, back on a 24" at the moment. Sadly I missed the reduced 9070xt on Overclockers. Though currently still looking at a 5070ti or 9070xt, I am not in a huge hurry, it seems a strange time to buy any GP at above retail when we have rumours of an Nvidia refresh of the current range planned this year, possibly new Nvidia next year, and people wishing for a 9080xt variant to compete with the 5080 by Christmas.
I still want 4k gaming at a high refresh rate though I am aware settings will need curtailed, but part of me feels like holding off on the GPU to see what is planned for release later, another part says get a case and more NVMe, and another tells me to just get something basic with no 12v cable that will let you play at 4k, another says get a 1080p card and hold off until new Nvidia 6000 is released. So choices will remain fluid on pay days with available deals on the day taking priority.
