New build: Photoshop / Blender / Video editing / Gaming
Permabanned
26 Jun 2025
UK
Hello!
It's time for a new build since my laptop died. I'd be using this build for working from home.
Last time I got advice from here was 12 years ago! (couldn't log into my old account :( )
Thanks!
Purchase Timeframe: within the next week
Budget: £1500-1700
Usage:
40% Photoshop - Digital painting / photo editing 2K+ resolution
20% Blender - Vehicle + hard surface modelling and rendering
15% Video recording (OBS) and processing (DaVinci)
10% Gaming - Currently playing Outer Worlds
15% Web browsing, Microsoft Office
Preferences: none.
Current Hardware:
- 1TB Samsung 970 Evo Plus NVMe.M2 (3years old - will use to store my reference images for work)
- 2TB WD WD2002FAEX Caviar Black (from a old pc build but still going - will probably use with a docking station as a backup drive)
- Monitors: HP Z27 27-inch 4K UHD,
Dell UltraSharp U2312HM 23'' Led HD (will upgrade when it dies)
- Wacom Cintiq
- Mouse + keyboard
Peripherals: none required
Special Needs/Requirements (inc Wi-Fi):
I'll be using a wired internet connection.
What is your opinion on AIO compared to air for the purposes I mentioned?
realistically you'd want the beefiest cooler you can get, especially when the high-end AMD and intel chips throw out 230w of heat at full pelt for hours on end.
for best performance, a 360mm aio is the correct choice here. albeit more failure points in comparison to a bog standard heatsink/fan.
tried to keep it on budget, but i couldn't. for £200 above your budget, you get: the best desktop (not xeon/threadripper) multicore cpu, and a 5070ti
it's £400 more than a intel 265k/506ti build, but if time is money, then i think the extra £400 is worth the outlay
My basket at OcUK:
Total: £1,902.91 (includes delivery: £0.00)​
The Thermalright Aqua Elite is excellent at its price point, but for super heavy use I would at least consider the Arctic Freezer III assuming the case supports it.
It's one of the better AiO's on the market due to having thicker radiators, temps should be better as a result and it has a fan on the HSF mount to help with VRM cooling etc too. Technically it is a little overkill, but as someone who isn't big on AiO's most of the time it's pretty much the only one on the market outside of the Thermalright options (such as recommended by @tamzzy) that I would consider.
My basket at OcUK:
Total: £213.92 (includes delivery: £3.99)​
B-Stock can be a bit of a gamble but OCUK are good on returns and do accept offers so you can often get a fair whack knocked off. For the 420mm I'd be wary, the case should support it when mounted at the front but it'll be a faff due to existing fan relocation and frankly probably overkill.
B-Stock offers thread: https://forums.overclockers.co.uk/threads/b-grade-clearance-and-forum-deals.18925626/
thing is that b-grade only has 6 months warranty, whereas arctic provides 6 years if bought new
also the asrock b850 pro-a has 14x80A VRMs for the vcore, so should be well up to handling a 9950x at full pelt indefinitely with minimal airflow
Aye, that's more than fair tbh. (I often forget the lack of real warranty on b-grade, tbh it's "better" than it was in OCUK but it should still match the initial warranty imo).
Still, for a hard running multi-core workstation I'd be inclined toward the Arctic, but it's more of a bias on my end than a real argument admittedly. Although part of that is something you brought up yourself, I don't doubt the Thermalrights but the warranty offered by Arctic speaks volumes imo, I could care less for a media machine but if I was making money?
My opinion depends on the CPU you pick, how much you're loading it and your tolerance for noise.
A 265K is fine with a decent air cooler (e.g. peerless assassin), but a 285K, not so much.
Short-term burst load can still be annoying on air (e.g. applying a filter/effect) if it pushes the power/temps up enough, though that can happen on water too, depending on how the fans/pump are set to ramp up/down.
Generally, I'd say:
- Ryzen 7: air is fine, but might need some fan curve adjustments for comfort with the boost.
- i7/Ultra 7: air is manageable, but needs a bit more tweaking for best results. Gaming no problem.
- i9/Ultra 9: not ideal, you can do it, but into micro-manage territory with power limits and fan curves.
- Ryzen 9: possible, especially with the 12 core CPUs, but much easier if you're willing to run with eco mode. Gaming is fine.
The above does depend on the CPU, since e.g. the Ryzen 7900 has very low power draw and is more comparable to a Ryzen 7 of the latest gen. A 14900K is also more power hungry than a 285K, not that I'd recommend buying either.
Note that the board is a factor too, since they often don't set the same power limits / boost behaviour. A video on the topic:
I'd be interested in a build with a 5070 Ti too, if that's okay.
Made some adjustments to the Intel build, now with air cooling, but a much stronger graphics card:
My basket at OcUK:
Total: £1,713.86 (includes delivery: £11.98)​
would be better off with an AIO even for a 265k
Yeah, I do agree for this usage, that's why I included one in my first spec, but going by TPU's review, Adobe apps and blender 'n such only used around 150, with just a small number of apps pushing north of 200. They're fairly cool running CPUs too, which would help.
Thanks for the explanation and insight on AIOs. Unfortunately I can't push to £1900 but thanks anyway.
I noticed the Zotac GeForce RTX 5070 Ti is current on pre-order at OCUK. Are there any alternative GPU's you could suggest as there doesn't seem to be an Eta for it.
